VWVortex.com - 96 2.0 sputtered out now won't start...
    Results 1 to 5 of 5
    Thread: 96 2.0 sputtered out now won't start...
    1. Member tashveedub's Avatar
      Oct 24th, 2005
      pgh
      91 vr, 02 tdi, 01 tdi, 99 tdi, 99 2.0
      04-23-2012 11:18 PM #1
      Car was fine then decided to sputter out and die. Now it will just turn over, and do nothing else. It's done the whole no start thing before and if I cleaned the maf and wiped the tb clean it would fire right back up. But haven't had to do that for a month or so. Aside of that, the intake boot/filter seem to be pretty wet. Btw, this isn't my car, a friend of mine. Just posting up to try n get a quick solution..
      He got it towed and I scanned it and here are the readings:
      VCDS-Lite Version: Release 1.1
      Monday, 23 April 2012, 20:24:29.
      Chassis Type: 1G - VW Golf/Jetta II
      Scan: 01,02,03
      Address 01: Engine Labels: 037-906-259.LBL
      Controller: 037 906 259 R
      Component: MOTRONIC M5.9 HS V01
      Coding: 00000
      Shop #: WSC 09449
      VCID: 2B2984AFCA0B
      5 Faults Found:
      16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
      P0134 - 35-00 - -
      16519 - Shareware Version. To Decode all DTCs
      P0135 - 35-00 - Please Register/Activate
      16826 - Shareware Version. To Decode all DTCs
      P0442 - 35-00 - Please Register/Activate
      16522 - Oxygen (Lambda) Sensor B1 S2: Signal too High
      P0138 - 35-10 - - - Intermittent
      16501 - Shareware Version. To Decode all DTCs
      P0117 - 35-10 - Please Register/Activate - Intermittent
      Readiness: 0010 0101
      End --------------------------------------------------------------------------------------------------
      I looked them up... O2 stuff, coolant temp, and evap/small leak. But would any of that really cause it not to turn start? I'm not very 2.0 friendly or mechanically inclined to know everything to look for/at, so any help would be more than appreciated! Thanks in advance to anyone with some input!
      aka vwtrash
      i make stickers, shirts, etc- pm me.
    2. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      80 Rabbit(DEAD), 94 Golf, '69 Type1 Sedan
      04-24-2012 10:26 AM #2
      Is there fuel pressure? A failed pump will not cause a code. Is there spark?
      Mar 23rd, 2008
      N/A
      N/A
      04-24-2012 02:31 PM #3
      #1 Check the fuses using a voltmeter, don't assume that they're good because you can't see a break.
      When you turn the ignition key to the start position, does the starter turn the engine at the normal speed?
      Does it turn faster than normal (faster than normal indicates broken timing belt)?
      Does the tach needle bounce (if not, bad crank speed sensor)? If the tach needle bounces, the ECU should be good, you need to check for spark, and if no spark, then suspect the ignition coil.
    4. Member
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      04-26-2012 10:38 AM #4
      Check for spark and fuel pressure. When you figure out which is missing, diagnose further.
      And register your VCDS-Lite. It'll be worth every penny and then some. Why is the car identified as Golf/Jetta II? If it's a 1996, it should be 1H -Golf/Vento III.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    5. Member tashveedub's Avatar
      Oct 24th, 2005
      pgh
      05-14-2012 08:50 PM #5
      Thanks guys! Btw not really sure why it came up as golf/ jetta II.. I didn't notice that before. But it ended up being a combination of bad grounds and a few other minor bits. Thanks again for the input!
      aka vwtrash
