VWVortex.com - MY10 Build
    Results 1 to 8 of 8
    Thread: MY10 Build
    1. Member MacProD300's Avatar
      May 19th, 2010
      ME
      2010 VW Tiguan Wolfsburg Edition APR Stage I
      04-24-2012 01:01 AM #1
      My Original plan was a retrofit headlight but the person could not deliver due to family problem and personal issue but had issue me a full refund. saw these on Ebay and wanted to take a leap and Glad i took the leap enjoy! I'll post more photos of my other retrofits but i had to upload this first because i know a lot of people been looking for a retrofit
      P.S. there are only 3 left ebay
      http://www.ebay.com/itm/Tiguan-5N-20...49154940385217
      APR Stage 1
      Install RNS-510
      retrofit backup camera
      retrofit GTI Steering wheel with paddle shifters
      LED Bi-Xenon Headlights
      Wish list
      APR Stage 2
      RIMS
      Payoff Car by the end of the year
      Mar 7th, 2010
      FEMA Zone 4
      04-24-2012 10:47 AM #2
      so is like a BMW Audi hybrid...
      its cool.
    3. Member TIGSEL's Avatar
      Dec 22nd, 2011
      The other side
      16 VW Golf R MT /// 12 VW Tiguan SEL 4Motion
      04-24-2012 01:21 PM #3
      How is the build quality? Looks like it is coming from China so I wouldn't be surprised if something fails soon (hopefully not). If I were you I'd do the water test and drive with my headlights on as much as possible while the warranty is in tact just to make sure.
    4. Member MacProD300's Avatar
      May 19th, 2010
      ME
      04-24-2012 02:00 PM #4
      The build quality is surprisingly strong but the only down fall is there is a battery type thing that dangles. I wish that they would of placed it inside the housing but with a little 3M tape and Electric tape to hid it will do the trick.
      I VAG-COM the DRL's so my low-beam are not the main DRL's so my parkers are on and fog lights are on this keeps the LED and the Angel eye on at all times.
      I wish there was a way to put the turn off the fog lights as DRL I tried a bunch of things on the long code even with the changing the lamp percentage to 1% X 1 does not work. this didn't work any tips with keeping the fog lights turned off.
      Cheers
    5. Member TIGSEL's Avatar
      Dec 22nd, 2011
      The other side
      04-24-2012 05:05 PM #5
      Quote Originally Posted by MacProD300 View Post
      Cheers
      I am no expert in Vag-Com, I don't even own a cable (yet). Have you looked into adding a euro switch, could it possibly fix that problem?
    6. Member MacProD300's Avatar
      May 19th, 2010
      ME
      04-25-2012 09:08 AM #6
      yeah i have the Euro switch i've done it before but i just don't remember what i did. i should of saved the long code.
    7. Member Keroppi_2.0T's Avatar
      Feb 25th, 2006
      Coolwater NYC
      13' S5 Coupe 3.0T 6spd APR Stg 2+, 09 VW GTI 2dr, 11 VW Tiguan 2.0T 4Motion SE APR k04, 14 Jetta TDI
      04-25-2012 09:10 AM #7
      Cheers
      Foglight as DRL is not a factory standard, it is an option in vagcom. i purposely set mine to it via vc.
    8. Member TIGSEL's Avatar
      Dec 22nd, 2011
      The other side
      04-25-2012 01:41 PM #8
      I know for a fact that your dealer can pull your original code for you. It take them 5-10 min.
