Results 1 to 3 of 3
Thread: in tank fuel pump (fuel sender) option
  1. Member hinshu's Avatar
    May 29th, 2001
    2012 135i, 1983 Golf (eurospec)
    04-24-2012 07:41 AM #1
    engine: ABF
    carbs: dual weber DCOE 45
    fuel pump: Carter #????? (dont have the number at the moment)
    problem: in tank fuel pump or sender unit, the one with the float ball does not function. I'm needing to find a replacement (which is proving difficult) or an alternative.
    part numbers or links to replacement are appreciated.
    t-minus 15 days till worthersee and it must run or im pushing it 800km
    Apr 27th, 2003
    oregon city, oregon
    79 dual carb rabbit ( the dark green one )
    04-24-2012 09:40 AM #2
    if you are talking about the fuel level sending unit, they are available from www.rabbitparts.com or www.germanautoparts.com. if you are talking about the fuel pump, you only need the carter pump by itself for carbs. you will also need a pressure regulator
  3. Member hinshu's Avatar
    May 29th, 2001
    04-26-2012 01:58 AM #3
    thanks for the response. ended up finding one locally. 89euro for a brand new oem unit.
