Results 1 to 14 of 14
Thread: A Leak. Not oil though...a little help..
  1. Member Teighlor O''s Avatar
    Aug 18th, 2011
    Cleveland, Ohio
    88 Scirocco 16v
    04-24-2012 10:20 AM #1
    I know its not oil, because i just changed the oil, its full, nice and clean, and the level hasnt gone down at all. This oil is reeeally black. It looks very similar to the nasty power steering fluid i have in my PS resevoir, but that isnt going down either. Its a pretty good amount of leakage, this has been going on for about 2 days. the drip is actually dripping from the lowest point on the flywheel case, although i assume its not actually coming from in there, but im having a really hard time finding the leak. Kinda worried its Gear oil, so im not driving it right now.
    Any ideas?
    Thanks in advance.
    I wouldnt hurt a fly. Unless it kept buzzing around in my face, and annoying me.
  2. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    04-24-2012 10:31 AM #2
    What does it smell like? Gear lube has a distinct odor.
    FS:Sunroof Deflector
  3. Member Teighlor O''s Avatar
    Aug 18th, 2011
    Cleveland, Ohio
    88 Scirocco 16v
    04-24-2012 10:35 AM #3
    I smelled it last night, but i cant remember now, and im at work.... Def doesnt smell like engine oil, i do remember that.
  4. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    04-24-2012 10:56 AM #4
    Well, I have to correct myself, synthetic gear lube may not have the "distinct odor" of dino gear lube. It could be gear lube, I would check the level and condition of the gear lube.
  5. Member Teighlor O''s Avatar
    Aug 18th, 2011
    Cleveland, Ohio
    88 Scirocco 16v
    04-24-2012 10:59 AM #5
    Yeah regular gear oil has that "grease" kinda smell to it, am i right? And honestly, i have no idea what the previous owner put in there. The time ive owned this car has been nothing but un doing all the dumb shart that the PO has done to it.
  6. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    04-24-2012 11:02 AM #6
    It has a stink like nothing else. That's how I look at it.
  7. Member Teighlor O''s Avatar
    Aug 18th, 2011
    Cleveland, Ohio
    88 Scirocco 16v
    04-24-2012 11:04 AM #7
    Haha ok, gotcha...
  8. Member scirocconaut's Avatar
    Oct 7th, 2011
    Dallas/pdx
    1979 16v mk1 scirocco S model black with roof rack and no sunroof :)
    04-24-2012 10:19 PM #8
    If it smells like battery acid and drips clear or blackish it could be coming from your ignition coil
    I know because it happened to me before and I didn't know what the hell it was coming from
    I also had on another occasion a oil temp sensor in the head that leaked only at speeds over 50 (the mess covered the leak each time it was cleaned and at low speeds wouldnt show )
  9. Member Teighlor O''s Avatar
    Aug 18th, 2011
    Cleveland, Ohio
    88 Scirocco 16v
    04-26-2012 04:25 PM #9
    Think it might be a rear main seal....F**K.
  10. 04-26-2012 06:13 PM #10
    Quote Originally Posted by Teighlor O' View Post
    Have you checked the gear oil? you just take out that 17mm plug on the drivers side front wheel. Make sure the car is on a level surface and fill gear oil into the trans until it starts overflowing.
    I usually take off the front driver wheel then take the plug out then put the wheel back on and fill it up.
    Its normal for a little bit of gear oil to leak around the final drive (CV axles).
  11. Member Teighlor O''s Avatar
    Aug 18th, 2011
    Cleveland, Ohio
    88 Scirocco 16v
    04-28-2012 08:04 PM #11
    Yep, rear main seal. So what all should i do while im doing the seal???
  12. Member lnoriel's Avatar
    Jul 31st, 2000
    Pasadena, CA
    1985 Golf GL with a 2.0l 16v, 1990 Corrado G60, 2011 Jetta SE
    04-29-2012 01:21 PM #12
    You're going to have to separate the trans and the engine. So might as well explore doing a clutch job and resurface the flywheel since they're going to be out anyways.
    You may also want to examine the trans seals as well as the output flange seals.
    1985 MKII Golf GL with 2.0l 16v
    1990 Corrado G60 TEC 2RS
    2011 MKVI Jetta SE
    corradog60project.blogspot.com
    mkiigolfproject.blogspot.com
  13. Member Teighlor O''s Avatar
    Aug 18th, 2011
    Cleveland, Ohio
    88 Scirocco 16v
    04-30-2012 09:10 AM #13
    Quote Originally Posted by lnoriel View Post
    Yeah i had planned on doing the clutch for sure.. So i dont have to pull the engine for this job, just drop the trans, correct?
  14. Member kaltblutig's Avatar
    Jun 26th, 2004
    Grand Rapids MI
    Well, It's a '49, '50, '51, '52, '53, '54, '55, '56 '57, '58' 59' automobile It's a '60, '61, '62, '
    04-30-2012 12:28 PM #14
    Correct.
