Results 1 to 6 of 6
Thread: Back passenger floor stays wet need help
  1. Semi-n00b
    Apr 14th, 2011
    roseville california
    2009 platinum grey jsw
    04-24-2012 10:42 AM #1
    Not sure but might have a leak. The back passenger floor under floor mat stays soaked. Not sure where it's coming from and can't get rid of it. Windows fog up on the inside overnight.
  2. 04-24-2012 04:47 PM #2
    Do you have a panoramic roof? I know that there was a thread on here recently about leaking being an issue some folks have.
  3. Semi-n00b
    Apr 14th, 2011
    04-24-2012 08:01 PM #3
    Yeah I got a pano. Gotta look for that thread
  4. Member leroyal's Avatar
    Jun 5th, 2006
    The City That Bleeds.
    2011 JSW TDI
    04-24-2012 08:21 PM #4
    There was a recall for B5 Passats for the very same problem...check with a dealership and raise he!! I smell a class action lawsuit brewing.
  5. Junior Member
    Aug 25th, 2006
    Miami, FL
    2010 JSW TDi
    04-28-2012 03:49 PM #5
    drain hose problem, pretty common from what i understand - get damprid and place in car ASAP and have dealer ck them - i had all four replaced. seems they are rigid plastic and get damaged in produciton.... get them fixed and then leave the damprid in car for a couple of days, its amazing how much water it will get... good luck
  6. Member Code3VW's Avatar
    May 5th, 2004
    Gilbert, AZ
    '10 CW JSW TDI 6MT
    04-29-2012 07:55 PM #6
    As mentioned, it is likely the drain plugs for the panoramic roof. Take it to the dealership and let them deal with it...
    OEM+ Bi-Xenon HIDs | Front & Rear Fogs | Highline CECM | Euroswitch | RNS-510 HW:08 SW:1140 w/ Software VIM | Backup Camera | 9W7 | Dash Cubby | Aspherical Mirrors | GTI Steering Wheel w/ .:R Badge | GTI 6MT Shift Knob | GTI E-Brake Boot | GTI Pedals | GTI 18" Detroits
    Not so OEM+ Koni Coilovers | Gentex Homelink Mirror | Yaesu FTM-350AR
