In the midst of installing my hydro to cable conversion on my o2a, I followed the Bentley and screwed a m8x22 bolt into the tranny to hold the throwout bearing lever back while installing the transmission on the engine. *I have a South Bend Stage 3 Daily clutch kit in it.*
I then removed the m8 bolt and I decided to try to move the arm on the cable actuating lever to see how easy it was to move the throwout bearing lever and I couldn't get it to move. Is this normal? I don't want to screw my new clutch up so I figured that someone on here might know something about this before I install the engine/tranny into the car and have to remove it to fix this problem.
Thanks in advance,
-Bob
