Results 1 to 19 of 19
Thread: Replaced speedo
    Mar 17th, 2011
    HURRICANE, UT
    1990 VW FOX 2 DOOR SEDAN
    04-24-2012 12:19 PM #1
    Ok well i just replaced my speedo with the new kph one. but now the clock doesn't work and blinker indicator is on and alt light on. Anyone have any ideas what I did? maybe plugged something in wrong. Oh and I broke the hazard switch. Would that cause that?
    V-DUBS DON'T DIE THE GET LOWERED!!
    Mar 17th, 2011
    HURRICANE, UT
    04-24-2012 01:53 PM #2
    Anyone?
    Aug 17th, 2011
    Brooklyn, NY
    '88 Fox GL Wagon, '04 Jetta GLS Wagon TDi, '89 Fox Coupe (sold)
    04-24-2012 02:40 PM #3
    did you swap out the L shaped green circuit board from the back of the old speedo?
    How a VW Fox Wagon sucked me back in...a build thread
  4. Member
    Aug 17th, 2011
    Brooklyn, NY
    04-24-2012 02:41 PM #4
    as long as you plug the two main plugs and the speedo - everything should work again.
    as for the hazard - you sure you are plugging it back into the correct spot? does your rear defrost work now?
    Mar 17th, 2011
    HURRICANE, UT
    04-24-2012 02:56 PM #5
    Quote Originally Posted by redone17 View Post
    did you swap out the l shaped green circuit board from the back of the old speedo?
    ???? My new speedo didnt have any circut baord. All i did was lift the circut board up and pull out the old speedo and put the new one in. Everything went back together the same way it came apart. Speedo, odo, trip, these things all work. And yes i made sure everything was plugged in right they are color coded. My hazard switch is not back in though. The plastic part broke coming out. The other part is still pluggd in though.
  6. Member
    Mar 17th, 2011
    HURRICANE, UT
    04-24-2012 02:58 PM #6
    Quote Originally Posted by rsay4654 View Post
    the only thing i can think that i may have done is the right hand plug under the cluster might be one or two pins off. Or maybe even backwards.
    Aug 17th, 2011
    Brooklyn, NY
    04-24-2012 03:02 PM #7
    that's the thing. the NEW speedo doesn't have the green board - you need to pull it from the old speedo and swap it.
    I would make sure those wires/plugs are not twisted - but they are impossible to be pins off - they are guided in and can only really snap in one way...
    Mar 17th, 2011
    HURRICANE, UT
    04-24-2012 03:04 PM #8
    Do you mean the circut board on the inside of the gauge? Like right behind the face?
    Aug 17th, 2011
    Brooklyn, NY
    04-24-2012 03:27 PM #9
    yup - it is held on by 3-4 clips and the pins that plug into the flexible circuit board - I don't have a picture handy - but can post one later...
  10. Member
    Mar 17th, 2011
    HURRICANE, UT
    04-24-2012 03:33 PM #10
    yup - it is held on by 3-4 clips and the pins that plug into the flexible circuit board - i don't have a picture handy - but can post one later...
    ****ty, thanks. Back out she comes...
  11. Member
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    04-24-2012 11:30 PM #11
    Yes, you'll have turn signal issues with a broken hazard switch.
    I really suck at smog.
    Mar 17th, 2011
    HURRICANE, UT
    04-25-2012 09:01 AM #12
    Quote Originally Posted by ziddey View Post
    okay got the circut board in, i thought everything was great. boy was i wrong. speedo works, odo works, clock works, but i still have no turn signals, gas gauge, temp gauge.
  13. Member doppelfaust's Avatar
    Aug 15th, 2007
    Tacoma, WA
    1988 Fox GL Wagon
    04-25-2012 12:12 PM #13
    Hazard could affect those things... replace the bad switch and troubleshoot from there.
  14. Member
    Mar 17th, 2011
    HURRICANE, UT
    04-25-2012 12:26 PM #14
    Ordered the switch. I was just seeing if maybe there was something else obvious. Would that cause the gauges to not work??
  15. Member j-boogie253's Avatar
    Nov 30th, 2009
    Tacoma, WA
    90 Fox, 91 Jetta, 98 A4 (RIP)
    04-27-2012 02:37 PM #15
    If the gauges don't work, i.e. gas gauge and temp gauge....it's probably a bad voltage regulator or it didn't get re-installed properly. The turn signal LED is on because of the bad hazard switch
    There is likely nothing really "wrong" with your cluster
    If you were a Volkswagen....who would your owner be?
  16. Member
    Mar 17th, 2011
    HURRICANE, UT
    04-30-2012 08:57 AM #16
    Quote Originally Posted by j-boogie253 View Post
    hazard switch is in.. turn signals work. i still dont have a fuel gauge or temp gauge. i am thinking voltage regulator as well. these worked before i stitched speedos.
  17. Member j-boogie253's Avatar
    Nov 30th, 2009
    Tacoma, WA
    04-30-2012 12:55 PM #17
    Yes definitely the voltage regulator then. It's that little 3 prong thing screwed to the back of the speedo. I've got some spares...
  18. Member
    Mar 17th, 2011
    HURRICANE, UT
    04-30-2012 01:50 PM #18
    yes definitely the voltage regulator then. It's that little 3 prong thing screwed to the back of the speedo. I've got some spares...
    so how would i go about replacing that??
  19. Member
    Aug 17th, 2011
    Brooklyn, NY
    04-30-2012 02:11 PM #19
    obtain one and plug/screw it in.
    it's probably a good idea to have a stockpile of those things...
