Results 1 to 3 of 3
Thread: boost leak at map sensor (FMIC)
  1. 04-24-2012 01:37 PM #1
    what is the best thing to use to seal b/w the map flange and map?
    Im giving RTV a try now.
    2003 Jetta 1.8T, APR Stage II ECU Upgrade, Forge 007 DV, 3" DP + 2.5" CB, Neuspeed Cone Filter, Silicone TIP, Forge TB Hose, FMIC, Snow Performance Stage II MAF actuated dual nozzle Water/Methanol Injection, NewSouth PowerGasket, 2.0TFSI igntion coils w/ IE adapters, Denso IK22 Iridium plugs @ .040", Ultimate N249/SAI/PCV/EVAP delete,catch can, ECS Stage II clutch w/ lightweight flywheel Need VCDS in Hampton Roads VA? PM me!
  2. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    04-24-2012 02:08 PM #2
    My Build
    FS: New in box, primer'd 20AE body kit (front+rear valences and side skirts) -- PM me for details
    FS: Fiberglass 20AE replica spoiler. No scratches. Reflex Silver.
  3. 04-24-2012 02:57 PM #3
    ahhh yes! I just figured that out... they sent me two of those inner fittings with the same size small hole, so I just didnt use it. I need the inner fitting with the large hole.
