this is exactly what i'm not a fan of cis-motronic (though my audi 5k runs perfectly *knock on wood*)
here are a few of my ideas (some may be far fetched)
- vacuum leak (like everyone else said)
- dead spot in your air box's potentiometer
- tweaked hall sender window in dizzy
- bad signal to ecu, bad signal to coil stage
since you mentioned bumping the harness and a few seconds of decent idle... i'd not only trace the harness for continuity, but also measure resistance. most likely there's an issue with the wires between the fuel distributor and the ecu.
it's a huge pain in the ass, because it's tedious work, but the one thing i've learned is to never trust a harness (even if you've built it yourself).
years and years ago i had an 88 digi car (split year) that didn't match ANY wiring diagrams anywhere, and had some mysterious gremlin that i just couldn't track down for months. i replaced this and that and nothing made any difference.
finally, while at my wit's end, i took a day and rebuilt the entire engine harness, reusing connectors, but rerunning and repining everything, and the gremlins were gone.
EDIT: you can also bring it up to me in brooklyn for a few days and i'll get it sorted for you.
