Results 71 to 105 of 118
Thread: I can't stand my car anymore....
  1. Member spoon!'s Avatar
    Sep 1st, 2005
    Monterey, CA
    '92 Jetta | '69 T3 Squareback
    04-26-2012 05:59 PM #71
    Quote Originally Posted by steveo27 View Post
    Rich ALWAYS comes through
    If you wanna be super knit-picky to figure out what it was, go through each wire and test the continuity. I'm (along with everyone else, im sure) curious to see what was the actual issue
    I was gonna say to stick a jumper on the CTS connector and ring out pins 6 and 10... just for giggles.
  2. Member robocopywriter's Avatar
    Jun 17th, 2004
    Los Angeles
    Mk IV R32, Mk II 16v Gti
    04-26-2012 07:12 PM #72
    I love a happy ending.
    Rent my house in Greece.
    http://kastro-greece.com
    Apr 21st, 2008
    MA
    Mk2 Diesel for sale
    04-26-2012 08:34 PM #73
    Badass!
    Nice work mate. The community works its magic again.
    USMC Graduated 1st RTBN C.CO. PLT 1028
  4. Senior Member Mr. Knappy's Avatar
    Oct 10th, 2006
    Levittown, PA
    1991 GTI 16v
    04-26-2012 09:51 PM #74
    Quote Originally Posted by robocopywriter View Post
    Depends what she looks like.
    I'll eventually check the comtinuity and resistance of all the wires and find out what was actually causing that. My guess is either the CTS, O2 sensor or the potentiometer on the fuel distributor. It wasnt the DPR since the idle went to like 2500 when i disconnected it and i was able to get a reading with the test harness. It would be nearly impossible for a knock sensor wire to go bad since those are so damn thick. These things are technically complexly simple. Not very much that controls the engine. I'm still going to replace the fuel distributor when it gets here and then do a final tune on it. Then we might start on the body and the rest of the interior. Headliner was jus done.
  5. 04-26-2012 09:58 PM #75
    sounds like you might be back
    A Dutty Dub
  6. 04-26-2012 11:28 PM #76
    I swap turbo diesels into all our MKII's
    Fixes everything
    Oct 6th, 2008
    Philly Area
    92 GTI 8v
    04-27-2012 09:56 AM #77
    Congrats man! Im glad you got it working!
    I am here: http://tapatalk.com/map.php?sp3pd1
  8. Senior Member Capt.Dreadz's Avatar
    Jun 3rd, 2003
    Long Island, NY
    VRT's & 2.7T's
    04-27-2012 12:50 PM #78
    Quote Originally Posted by Mat_16V View Post
    i got pissed at mine now it has holes in the hood
    I'm no Horatio Caine but it looks like the hood was off & stood up against something before being shot.
    Stick with it Knaps
    Chosen Life Clothing. Streetwear for the car culture. Launch Party coming very soon!!
    Meet Long Island The place if you're looking for a euro GTG in the Long Isl./New York City area.
    FaceBook: Carlitus Christensen Sr. - Instagram: @ThatDreadLife - Twitter: @ThatDreadLife
    Kicks...Clothes...Cars...Ho's...THINGS I DO BEST!
  9. Member choochoo's Avatar
    Nov 12th, 2008
    OC, CA
    04-27-2012 01:13 PM #79
    Quote Originally Posted by Capt.Dreadz View Post
    Stick with it Knaps
    See, he's back to his old self, pointing the newbs the right way. This was just a minor hiccup
    Quote Originally Posted by Mr. Knappy View Post
    The c-clip goes onto the little groove on the end. Make sure you squeeze it tight or you won't get the gear on. Then you just push the gear on till it clicks. Test by pulling on it. Then that gets installed into the gear box. New ones can be a pain to get in. Takes some patience. I actually used an old O2 sensor socket to lightly tap mine in.
  10. Member Soup Guy's Avatar
    Jul 5th, 2002
    earth
    04-27-2012 01:20 PM #80
    lso agree that a vacuum leak could make it do that. Injector O-Rings?
  11. Senior Member Mr. Knappy's Avatar
    Oct 10th, 2006
    Levittown, PA
    1991 GTI 16v
    04-27-2012 01:54 PM #81
    Quote Originally Posted by Soup Guy View Post
    Nope, the wiring harness did that.
  12. Member oldskoolracer's Avatar
    Mar 6th, 2009
    Clearlake, California
    1989 Volkswagen Golf GTi, 79 Plymouth Volare 225 supersix
    04-27-2012 02:30 PM #82
    Glad you got it figured out , been having the same issue with mine and after hours on end and a couple hundred $$ in parts I found that the head gasket was blown. Not mixing fluids, but burning coolant and losing compression through the cooling system
  13. Member mk2fu's Avatar
    May 13th, 2007
    Ontario
    04-27-2012 05:01 PM #83
    glad everything worked out. i bet youre even happier you didnt scrap it now, time to fall back inlove with it! ... until the next problem arises. Good work.
    bankrupt.
  14. Semi-n00b
    Apr 11th, 2012
    Richmond, BC, Canada
    1991 Jetta Coupe
    04-27-2012 06:22 PM #84
    SEE..........WE KNEW YOU COULD DO IT!!!!
  15. Member Run_That's Avatar
    May 15th, 2009
    Sturgis, MI
    04-27-2012 06:23 PM #85
    Glad to see you doing something with this again sir.
    '91 GTDECO
  16. Member
    May 24th, 2001
    San Diego CA
    92 JackStand Edition
    04-27-2012 07:15 PM #86
    Quote Originally Posted by Project_2501 View Post
    ...The community works its magic again...
    nice to see this in the MK2 forum, a rare thing as of late...
  17. Senior Member Mr. Knappy's Avatar
    Oct 10th, 2006
    Levittown, PA
    1991 GTI 16v
    04-28-2012 02:53 PM #87
    Thanks everybody. Drove it like 10 miles today. It was nice to be out in it. Seriously thought it stalled every time it went to idle.
  18. Member Soup Guy's Avatar
    Jul 5th, 2002
    earth
    04-28-2012 04:20 PM #88
    Oop. Sorry. Reading is greater than me I guess. Glad you got it working!
  19. Member Ice.dk's Avatar
    May 27th, 2007
    Karup J Denmark
    1986 Golf GTI 16v project car 1996 Audi A4 B5 1,9 TDI Quattro Daily driver
    04-28-2012 05:54 PM #89
    hmm sounds funny
    i think i could be a hall sender with a bad connection maybe, vacum leak, what about the cold idle does that work all the time maybee a bad thermo switch
  20. Senior Member Mr. Knappy's Avatar
    Oct 10th, 2006
    Levittown, PA
    1991 GTI 16v
    05-01-2012 01:20 PM #90
    One great thing about it running good now is that the fuel mileage went from between 14-19mpg to this:
    That was the 22 miles drive home from work. Mostly city, too.
  21. Member db3ck's Avatar
    Sep 2nd, 2011
    Flint, mii
    86 vw jetta 90 b3 wagon
    05-01-2012 01:44 PM #91
    wow thats really good must be nice to see that
    Eva: 90 b3 wagon
    Whore: 86 jetta
    i my dubs
  22. Senior Member Mr. Knappy's Avatar
    Oct 10th, 2006
    Levittown, PA
    1991 GTI 16v
    05-01-2012 01:52 PM #92
    It is nice but I know it's running a little lean so it will change once the new fuel distributor gets here at the end of the week.
  23. Member db3ck's Avatar
    Sep 2nd, 2011
    Flint, mii
    05-01-2012 02:44 PM #93
    o cool beans i cant wait till i get my mk2 up and running its gunna be a lovely day when it comes
    Eva: 90 b3 wagon
    Whore: 86 jetta
    i my dubs
  24. Member under the radar's Avatar
    Mar 5th, 2007
    NOR-CAL COASTSIDE
    disco, new wave, rave era german iron...and a Japanese V8 with a tailgate
    05-01-2012 03:39 PM #94
    my '91 GLi had the same issue. solved it by getting the T-body idle stop/ idle switch perfectly adjusted with a feeler gauge. my car idles perfectly, but if i move the idle switch even 1/2a mm it will get that surging idle. makes me wonder if my harness has the same issue. let me know what you find when you test your old harness.
    Quote Originally Posted by spoon! View Post
    I'll go if Paul goes.
    Rod Blagojevich - Team My Little Pony
  25. Senior Member Mr. Knappy's Avatar
    Oct 10th, 2006
    Levittown, PA
    1991 GTI 16v
    05-01-2012 08:10 PM #95
    Quote Originally Posted by under the radar View Post
    I'll be digging into it more here in a few.
    I took a picture...
  26. Member .:R32:.'s Avatar
    Feb 14th, 2012
    Dallas, TX
    2004 TR R32
    05-01-2012 08:35 PM #96
    This is looking really good!!
  27. Senior Member Mr. Knappy's Avatar
    Oct 10th, 2006
    Levittown, PA
    1991 GTI 16v
    05-01-2012 08:47 PM #97
    Thanks.
    I think we might have found the issue in the harness. I think. I have continuity between the CTS wires, O2 sensor wires, DPR wires but NOT the ISV. Now, the only thing is, the ISV has a fuse on the fuse panel. Does the ISV run to the fuse panel before going back or what? I don't have the patience to figure it out nor do I care so I will jsut make myself feel like that was the issue.
  28. Member robocopywriter's Avatar
    Jun 17th, 2004
    Los Angeles
    05-01-2012 10:07 PM #98
    So wait... the ISV was working but there was no continuity in the wire?
    Thanks for posting what you found by the way... hate it when people don't do that.
  29. Senior Member Mr. Knappy's Avatar
    Oct 10th, 2006
    Levittown, PA
    1991 GTI 16v
    05-03-2012 01:35 PM #99
    I think that is because the ISV is powered through the fuse box. Who knows. I did get 12v to it before I removed the harness. I still don't have a clear reason why that was going on.
    Anyways, I replaced the fuel distributor and intake tube.
    Pretty sure one of the two is either from a Passat or regular CIS-e.
  30. Member under the radar's Avatar
    Mar 5th, 2007
    NOR-CAL COASTSIDE
    05-03-2012 01:40 PM #100
    the one installed on the car is from a passat.
  31. Senior Member Mr. Knappy's Avatar
    Oct 10th, 2006
    Levittown, PA
    1991 GTI 16v
    05-03-2012 01:44 PM #101
    I figured. Oh well. It fits and it works.
  32. Geriatric Member VegasJetta's Avatar
    Jan 26th, 2003
    SoPo, Maine
    89 Helios GLI, 01 XJ 4.0, 96 Impreza Syncro, 87 Honda TRX250
    05-03-2012 04:17 PM #102
    Quote Originally Posted by anterrickson View Post
    ... And the sunroof bug deflector?
    I have two here for you. I will be in Philly in August, I will bring you one if you can wait...
    Quote Originally Posted by JacksSenseOfRejection
    Here's a fun fact: if someone is hitting you with a metal pipe, stay down.
  33. Member robocopywriter's Avatar
    Jun 17th, 2004
    Los Angeles
    05-03-2012 07:26 PM #103
    hmmmmm... I wonder about that circuit. My ISV works and everything works perfectly 90% of the time. But it has some random idle problems that come and go.
  34. Senior Member Mr. Knappy's Avatar
    Oct 10th, 2006
    Levittown, PA
    1991 GTI 16v
    05-03-2012 10:29 PM #104
    Quote Originally Posted by VegasJetta View Post
    Do it, you won't.
  35. Member under the radar's Avatar
    Mar 5th, 2007
    NOR-CAL COASTSIDE
    05-03-2012 10:43 PM #105
    i think the passat ones have a nicer shape anyways.
