VWVortex.com - decked twice vw aba 2.0 head
    Results 1 to 9 of 9
    Thread: decked twice vw aba 2.0 head
    1. Junior Member
      Jun 29th, 2011
      Enfield, CT
      97 cabrio, 98 A4 2.8
      04-24-2012 05:35 PM #1
      The machine shop I sent the head to told me that the head was already rebuilt and decked before from what they could see...I am getting the pinging noise and I believe I have an exhaust leak at the manifold. Will getting an adjustable cam gear help my case if I can retard or advance it by a few degrees? The leak wouldn't affect the pinging at all, correct? Also, where would be my best bet for a good cam gear that isn't too high priced, I'm not looking for performance, just something to stop the pinging!! thanks in advance!
      -Derek
      I'm sorry if there's a thread that talks about this, if there is I can't seem to find one that talks exactly about this type of situation.
      Mar 31st, 2008
      PNW - Oregon
      04-24-2012 08:20 PM #2
      Quote Originally Posted by fitsofrage99 View Post
      -Derek
      fix your exhaust leaks first.. then see if you are actually PINGING..
    3. Junior Member
      Jun 29th, 2011
      Enfield, CT
      04-24-2012 10:43 PM #3
      thanks man lmao
    4. Member
      Sep 10th, 2011
      jupiter fl
      1997 jetta trek II 2.slo 04 lincoln towncar
      04-24-2012 11:43 PM #4
      Run 93
    5. Junior Member
      Jun 29th, 2011
      Enfield, CT
      04-25-2012 07:13 AM #5
      gotta half tank of 93 and a full bottle of seafoam in there....
    6. Member
      Sep 10th, 2011
      jupiter fl
      04-25-2012 08:00 AM #6
      ive never seen a exust leak cause a engine just never ce to ping preignition but who know maybe ive just never come across it
    7. Senior Member tdogg74's Avatar
      Mar 1st, 2002
      In a tea cup
      Previous: 1997 8v Golf. Current: 2000 1.8t Passat
      04-25-2012 08:16 AM #7
      First off, how did your machine shop determine your head was already 'decked'? Did they CC the combustion chambers and compare those numbers to a stock head? If it was just 'resurfaced', then that is generally only .002"-.004" of material removed and will have close to zero effect on your compression ratio. Did the machine shop remove more material from the head? If so, how much?
      Second, are you sure you used the correct exhaust gasket on the rebuild? Are all the manifold nuts tight?
      Lastly, advancing/retarding effects your cam timing, not your ignition timing. So no, an adjustable cam gear is going to do nothing. Your ignition timing is self adjusting.
    8. Banned Hurt's Avatar
      May 3rd, 2011
      Boston, MA
      1998 Jetta GT, 1998 GTI 2.0, 2012 GLI, 2012 GTI
      04-28-2012 09:18 PM #8
      ^ x2
      If you want a performance cam gear, get a TT tuning one. Don't buy a all aluminum one, it'll shred the timing belt. TT sells a nice one for about 70 bucks, I think. Maybe 100.
    9. Member AJmustDIE's Avatar
      Dec 22nd, 2010
      Ocala, Florida
      97 Black GLX, RIP 97 White 8vT Jetta Trek
      04-30-2012 03:06 AM #9
      Quote Originally Posted by 1997SLOW View Post
      Run 93
      It's Timmy with mmmmMojo, i have returned
      8VALVETURBO - RIP White Jetta
