bump
#1
I have a 914 w/a widebody kit & super wide fuchs on the rear. needs a little TLC on the body, motor has less than a k on the rebuild 4cyl-runs & starts up like a top. single carb. the pan is in 'OK' shape-has 2 small holes about in inch in diameter behind both seats. the speedo doesnt work. has carbon fiber dash inserts & carbon fiber ****er bezel, other than the 2 small holes behind each of the seats the floor is solid w/the exception of some surface rust. the pass side door handle needs some work or replaced. It only opens from the inside.Wheels are true fuchs.... tire sizes are Rear bf Goodrich 245/50/15 Front bf 205/50/15. I didnt climb under the car, but had it on my friends lift. alittle rust here & there but no real rot that I saw. I got the car from a very close friend that had had it over 12 years & I got it last sept.
Now for the really bad-the tranny is shot (its a 5spd). I dont have the time or the interest it fix this car. car will have to be towed.
comes w/a box of parts & memorabilia
I have tons of pics apon request.
looking for a cabby...
