Results 36 to 70 of 72
Thread: my big turbo set up
  1. Member formerly silveratljetta's Avatar
    Feb 6th, 2007
    2000 Jetta 1.8T Drag Car, 2001 Jetta 2.slow daily beater
    05-05-2012 12:31 PM #36
    Quote Originally Posted by schwartzmagic View Post
    Shouldn't you focus on getting your tune/fueling issues figured out first before you even begin contemplating upgrading your rear beam and rear suspension in the future? Just saying...
    Sent from my MB860 using Tapatalk 2
    Whoa relax there buddy relax. Who said anything about upgrading my rear beam?
    Jun 10th, 2011
    Fort myers
    05-05-2012 01:45 PM #37
    custom fitting on rad, catch can coming along...
    First mk4 in the 9S, First to run 10s-9s on stock ECU. Right Here!!
    Jun 10th, 2011
    Fort myers
    05-09-2012 08:27 AM #38
    custom hotbits.ca suspension came back revalve for custom swift performance coil spring rate, spherical bearing in control arms
    custom VAP 02j case brace really helps with reducing flex
  4. Member DBVeeDB's Avatar
    Aug 2nd, 2007
    LZ, IL
    '08 B6 3.6 4mo Wagon
    05-09-2012 09:01 AM #39
    can you briefly describe more about that trans brace? Im not sure I quite understand what there is to flex.
    I am trying to strengthen my 02j as much as possible without going to a 6spd. So I love when I see new stuff come up.
    Thanks, and amazing build so far Every time I see a custom cage it makes me wish I went that route.
    -Devin :: Bt/shaved bay Jetta, never running:: PART OUT THREAD
    :: B6 3.6 4MO Passat Wagon ::
    Jun 10th, 2011
    Fort myers
    05-09-2012 09:12 AM #40
    we had issues with breaking trans case, under extreme load these aluminium/magnesium case flex and gears push apart and well rest is history, since i have not done the Billet bellhousing yet, these are good alternative in adding strenght without breaking the bank.
    We were using this brace on our hotrod wich ran 28" slicks, once in awhile still broke but would just crack and not damage the gears, so just for that saving a 5k gear set as been more then worth it
  6. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    audi tt gt3076r 01 aston martin db7 04 land rover disco 99rolls royce seraph
    05-09-2012 09:30 PM #41
    At what power does the trans start having problems???
    http://forums.vwvortex.com/showthrea...t-done-I-guess
    ^^^Big Turbo build lots of pics^^^
    Best shop for repair and custom workin ma
    http://www.wentworthmotorsports.com/
  7. Junior Member bbjetta87's Avatar
    Jun 21st, 2009
    610 pa
    girl car with a turbo
    05-09-2012 10:07 PM #42
    beautiful build
    "So, just installed my ecu...
    Now I need new tires... and a new clutch... and some new pants..."
    Gonzo Tuning
    Jun 10th, 2011
    Fort myers
    05-10-2012 07:20 AM #43
    the pinion brace is good to have at over 350ft/lbs added insurance, this case brace is again insurance but our set up is making over 600ft/lbs, but making case stiffer on lower HP TP level will only add reliability.
  9. 05-10-2012 08:51 AM #44
    Definitely interested in buying one of those braces off your site. My O2Js getting pulled apart now to see what I need to freshen up.
    MK4 Junker : PAG 50trim Kit : AEB : RMR : Eurodyne
    P.P.T. - Pag Parts Turbo
    B6 A4 : Slow
  10. Member
    Jun 10th, 2011
    Fort myers
    05-10-2012 09:10 AM #45
    pm
  11. Member
    Jun 10th, 2011
    Fort myers
    06-02-2012 06:19 PM #46
    get use to this View, alot of new custom stuff, that im very proud of, was a pleasure to work with O&J and Gato Performance, from our design to there expert quality fabrication i really believe we have done a great job in covering all aspect of a well built kit, this will fly and i have no dought... Finaly back at the shop and work starts monday.
    800whp motor waiting to go to work
    PAR gear set ready to run small 24.5, we fix all the issues with 26" so these small tires will be a breeeze
  12. Member 18T_BT's Avatar
    Sep 15th, 2005
    Silver Spring, MD
    2002 1.8T JETTA & 2000 TTQ
    06-02-2012 06:51 PM #47
    looking good marc andre
  13. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    1984 GLi 20v, '06 M3, '10 Ninja, '10 690 Duke
    06-02-2012 06:57 PM #48
    Sent from my SPH-D710 using Tapatalk 2
    :HOMEGROWN MOTORSPORTS:1:4.9 VulcanWorks SuaSponte #13Dead Rabbits 1.8l20vAEB3651GonzoFerrera1000cc1552.billet3071rSE M80mmAWIC.H&R.PagParts.Snow034clutchmasters.IE.198 4JettaGLi
    Quote Originally Posted by frechem View Post
    I like my women how I like my whiskey; aged 18 years and mixed up with coke.
  14. Member Andaloons's Avatar
    Apr 16th, 2004
    Houston, TX
    2004 GLI 02M; 1997 Ford F-150
    06-02-2012 07:06 PM #49
    Amazing.
  15. Member One-Eight GTI's Avatar
    Jan 4th, 2010
    Duluth MN
    01 GTI 1.8T
    06-02-2012 07:26 PM #50
    Damn Marc, Its coming along nicely
    Brute 20mm Connecting Rods, ACL Bearings, Wiseco 83mm Pistons, FSI Crank, AEB Head, CatCams 3658, PagParts GT3076R Bottom Mount V-Banded Turbo Kit, PagParts Garret 550HP Core, VF Engineering Motor Mounts, SEM IM, Labonte W/M, 70mm TB, Tial Q BOV, Tial Wastgate, Turbosmart Dual Stage Boost Controller, Peloquin LSD, Clutchmasters FX400, 910cc Injectors, IE Surge Tank, Eurodyne with Maestro.... PAGPARTS Clear Water Dubs
  16. Member
    Jun 10th, 2011
    Fort myers
    06-02-2012 07:39 PM #51
    thanks, still got lots of work left, but this week ill try and do alot since would like to make test run June 24
    first NDIMA event here is West palm beach, but won't rush, if it's done we are going if not will test when ready
  17. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01 Jetta Wolfsburg Ed, 92 Honda Prelude Si JDM H22 Swapped
    06-02-2012 08:52 PM #52
    Holy $hit Marc! That Build Loos Very Impressive!
    My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
  18. Member
    Jun 10th, 2011
    Fort myers
    06-03-2012 07:28 AM #53
    thanks, really looking for consistent fast times with this one
  19. Member Twopnt016v's Avatar
    Jul 5th, 2009
    1983 2.0 16v turbo bunny, 1991 2.0 16v Gti, 1986 Jetta Coupe 2.0 16v, 2002 337 Gti, Giannini R1
    06-03-2012 07:59 AM #54
    Nice work and attention to detail...I'm sure you'll have no problems with those consistent FAST times
  20. Member One-Eight GTI's Avatar
    Jan 4th, 2010
    Duluth MN
    01 GTI 1.8T
    06-03-2012 08:36 AM #55
    Marc how many injectors are you going to run??? In this pic I see an extra port for something in your runners
  21. Member
    Jun 10th, 2011
    Fort myers
    06-03-2012 08:38 AM #56
    We can run 8 injectors with this custom intake true street is the start going bigger later on,
  22. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    06-03-2012 10:24 AM #57
    Quote Originally Posted by xtremvw3 View Post
  23. Member The*Fall*Guy's Avatar
    Aug 10th, 2009
    There
    06-03-2012 03:46 PM #58
    Sweet! Are you coming to the northeast this season? Would like to see this run
  24. Member 3071R-GLI's Avatar
    Aug 26th, 2006
    S Florida
    05 PTE-6057 GLI
    06-03-2012 03:57 PM #59
    Car/setup is really nice Marc, and I am sure will run a serious #. can't wait to see it run at PBIR
    05 Jetta GLI 1.8T (E-85)10.63@139
    USPMotorsports
    Eurodyne
    Pagparts
  25. Member
    Jun 10th, 2011
    Fort myers
    06-03-2012 05:08 PM #60
    Deff want to run northeast but will deff run it here alot before driving there
  26. Member stevemannn's Avatar
    Apr 17th, 2008
    the dirty burg pa
    1994 huffy 10speed
    06-03-2012 05:14 PM #61
    VIDEOS......NOW!!!!!!
    Quote Originally Posted by speeding-g6O View Post
    so yeah, i wanna get me some of those hid lights, so i can see the girls in the dark better so i can pick them up and go skating. i like skating. i never did speed skate, as i am sort of odd shaped. people have called me an "egg on stilts" which means i am kind of top-heavy. with skinny long little legs. i prefer smooth and sleek like a stork, but then people say it rhymes with "dork" so that doesnt work.
  27. Member The*Fall*Guy's Avatar
    Aug 10th, 2009
    There
    06-03-2012 05:30 PM #62
    DO IT!! pllllllleeeeeaaaase come to w/f!!
  28. Member
    Jan 8th, 2009
    farmingville,ny
    03 vw gti ...WWW.STEVEBILT.COM
    06-03-2012 06:40 PM #63
    Come here for waterfest ... Btw i sent you a message on Fb check it out
  29. Member
    Nov 9th, 2009
    Miami,FL
    mk2 24V VR6
    06-04-2012 07:04 PM #64
    Quote Originally Posted by Mike Pauciullo View Post
    y don't you guys come to race to Florida? so you can see some street cars with exhaust out the hood
  30. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    06-04-2012 07:12 PM #65
    Quote Originally Posted by A267MM View Post
    lol
  31. Member
    Jan 8th, 2009
    farmingville,ny
    06-04-2012 07:14 PM #66
    If i have the funds for it I will come down...I will try to drag kb down there with me
  32. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    06-04-2012 07:15 PM #67
    lmk when/if this happens
  33. Member
    Jan 8th, 2009
    farmingville,ny
    06-04-2012 07:25 PM #68
    Quote Originally Posted by Big_Tom View Post
    I would be interested in coming down ...any events in December or January?
  34. Member
    Nov 9th, 2009
    Miami,FL
    mk2 24V VR6
    06-04-2012 08:14 PM #69
    should be fun u guys coming down
  35. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    06-04-2012 08:27 PM #70
    not sure, ur asking the wrong guy. I dont attend any events
