VWVortex.com - Y coolant hose connector!
    Results 1 to 18 of 18
    Thread: Y coolant hose connector!
    1. Member sponcar's Avatar
      Feb 5th, 2010
      Alhambra, CA
      01 VW Jetta wolfb
      04-25-2012 12:32 AM #1
      I found that the other day my car was leaking coolant, so now that i had some free time I popped the hood and checked it out where the leak was coming from. By simple look, I found it was somewhere near to the water/coolant tank on the passanger side.
      I checked all the hose and ended up having a two fingers crack on this plastic piece with a part number
      0257 >PA66-GF30< I visited my local auto parts and none of them have it. They offered me some T hose adapters that honestly i didnt want to deal with it since there is not enough room to play with all the hoses.
      Could someone help me find a better way to look up for this part. Otherwise i might try the dealer.
      -God created turbo lag to give the v8's a brief moment of hope-
      #workingclass society
      BUY MY STUFF
      http://forums.vwvortex.com/showthrea...Back-to-stock!
    2. Member codergfx's Avatar
      Jan 10th, 2009
      Cali
      03 GTI GT3076r, 03 JETTA K03, 03 AUDI A4 GT3076R
      04-25-2012 12:54 AM #2
      i actually just replaced mine not to long ago just got it from the dealer.
      MY BUILD | - GT3076r, 3" to 2.5" turboback exhaust (vbanded), Tial 38mm wastegate, fx400 6 puck, Peloquin LSD, VF Poly Engine Mounts, Greddy Profec B Type II, walbro 255 inline fuel pump, ID1600cc @ 3bar running on e85. AMB head, AWD bottom end. 434whp 369wtq @ 30psi (OLD: 383 whp 333wtq @ 23 psi)
    3. 04-25-2012 12:58 AM #3
      haha, just fixed the exact piece myself.
      Just grab one from the dealer, it's not that bad less then $25 for the part if I remember correctly. Also it includes the hose that goes to the lower portion of the coolant ball. Just be careful because when I first asked for the part, the part number was wrong in the VW system and the dude came out with some part that costed like $75 but it was the wrong one. I pointed out the mistake by looking at the screen and explaining it again and he brought back the right piece. Since you have it out I suggest bringing it with you.
      During replacement I didn't lose that much coolant, as I unbolted the coolant ball and tipped it on it's top while I replaced the bottom hose so nothing really dripped out. The feed for the line comes from the front of the block, it's the first T off the hardline that goes around the driver side of the car eventually ending in the feed to the heater core. The other part of the Y goes into the turbo feed line.
      Easy Fix, took some pliers a screwdriver and like 10 mins total.
    4. Member Big_Tom's Avatar
      Aug 19th, 2007
      Orlando, FL
      01 Jetta Wolfsburg Ed, 04 Jetta GLI 24v 6spd
      04-25-2012 01:00 AM #4
      I'm pretty sure i still have that y pc in my garage if you want it. PM me if you do
      My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
    5. Member sponcar's Avatar
      Feb 5th, 2010
      Alhambra, CA
      01 VW Jetta wolfb
      04-25-2012 02:49 AM #5
      Thanks guys, I was scared to be asked for more than 40bucks at the dealer for that little piece haha..
      If i dont get it by tomorrow, ill hit you up big tom.
      BUY MY STUFF
    6. Member Big_Tom's Avatar
      Aug 19th, 2007
      Orlando, FL
      04-25-2012 06:01 AM #6
      Quote Originally Posted by sponcar View Post
    7. Member Cody2003's Avatar
      May 19th, 2009
      Simi Valley, CA
      '03 GTI 1.8T
      04-25-2012 06:45 AM #7
      http://www.ecstuning.com/Volkswagen-...oses/ES307275/
      Theres a link to the part. Mine broke a while back and the dealer sold me the Y with the hose as one piece.
    8. Member armymech666's Avatar
      Sep 29th, 2007
      Duncannon, PA
      2001 jetta 1.8t, 1990 jetta 16v, 1982 Caddy Diesel
      04-25-2012 12:49 PM #8
      I replaced mine with a brass T fitting from home depot. It worked perfectly and I will never have to worry about it breaking again. Oh, and it was waaaay cheaper than the crappy plastic piece.
    9. Member sponcar's Avatar
      Feb 5th, 2010
      Alhambra, CA
      01 VW Jetta wolfb
      04-26-2012 10:34 AM #9
      ^ i know it should be way cheaper to make your own with home depot or a local auto parts.
      I got it from the dealer for $30 just same piece plus a little hose like the one in the link posted above.
      Thanks everyone
      BUY MY STUFF
    10. n00b
      Jul 19th, 2014
      Illinois
      2000 golf 2.0 (rip). 2002 gti 1.8t
      07-19-2014 02:45 AM #10
      http://www.jcwhitney.com/replacement...FQ1gMgodSUEAAQ
      Found one for 20 bucks. I picked mine up for 17 with a code.
    11. n00b
      Dec 29th, 2013
      San Antonio, TX
      MK4 VW GTI 1.8t
      07-19-2014 11:49 AM #11
      http://www.ecstuning.com/Volkswagen-...ing/ES2748757/
      I bought this to upgrade mine even though it hasn't started to leak. For pretty about the same cost (few $ extra), I no longer have to worry about this peice leaking.
    12. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      07-19-2014 03:08 PM #12
      Quote Originally Posted by socram_hd View Post
      It was cool that ecs jumped in and made a cast version after usrt made a billet version and gruven parts made a stainless version. Lol
      My Build
      Welcome to the world of racing! Budgets are ALWAYS exceeded, deadlines are never met, end-goals never reached, and wives always unhappy... it's all worth it though!
    13. Member
      Aug 1st, 2012
      Raleigh, NC
      04 GTI 1.8t, 02 Passat 1.8t
      07-19-2014 06:58 PM #13
      Just don't cheap out and get this MTC piece of crap.
      http://www.ecstuning.com/Volkswagen-...ses/ES2713297/
      Mine lasted 3 months and fell apart in my hands.
    14. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      07-20-2014 03:38 PM #14
      Quote Originally Posted by cwyamz View Post
      With metal versions available. Buy a metal version. Period.
      My Build
    15. Member Slimjimmn's Avatar
      Apr 8th, 2006
      Rochester, MN
      MK4 shaggin wagon
      07-21-2014 01:24 AM #15
      Oem part lasts 10years and 150k miles and is 1/4 the price.
      the car is on an inclined driveway and up on jack stands in the front only
      04 Jetta Wagon 2.slow------>Family man now
    16. Banner Advertiser ECS Tuning's Avatar
      Oct 2nd, 2006
      Wadsworth, OH
      Modified Ones
      07-21-2014 11:17 AM #16
      Thanks for sharing our link to our new product!
      Andy
      :: Phone: 1.800.924.5172 - Hours: Mon. - Fri. 8:00AM - 11:00PM EST Saturday 10:00AM - 7:00PM EST :: Email: sales@ecstuning.com & customerservice@ecstuning.com :: Facebook :: YouTube :: Live Chat :: Instagram
    17. n00b
      Mar 31st, 2015
      Soweto
      Golf IV GTi 2001
      03-31-2015 09:30 AM #17
      I now find myself looking for the same stupid pipe, no1 has it... #sorb
    18. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      03-31-2015 12:01 PM #18
      Ecs, gruven, usrt
      My Build
