Please post a valid auto-scan.
This data is incomplete.
#1
Situation: After using VAG-COM, I now have a bulb out indication; my MFD says "Left Turn Signal Not Working" and also "Right Turn Signal Not Working". I did not change anything of significance and even changed back, still have the bulb out indication. No lights whatsoever are out... I have checked several times.
So I have looked into this for a little while and fell short of a resolution. The best thing I could find is this which is the exact same situation as mine, but no resolution!
Does anyone have an idea? I've tried everything the other guy tried as well, including the cold diagnostics.
Se below for VAG-COM fault readout.
Thanks for any help!
Sean
Tuesday,24,April,2012,22:02:23:49034
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 55 56
VIN: WVWEV71K07W227714 Mileage: 65570km/40743miles
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWZ7Z0G8080142
Coding: 0403010A18070160
Shop #: WSC 01279 785 00200
VCID: 2B7BD38D8A1E111
No fault code found.
Readiness: 0000 0001
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73CB0BED12AE091
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 GL
Component: Climatic PQ35 120 0606
Shop #: WSC 00000 000 00000
VCID: 74C908F117A00E9
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000006827506
Coding: A78DCF294004150047140000001400000018F70B640001
Shop #: WSC 91590 999 58568
VCID: 6CF910914F90D69
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 080307 020 0501
Coding: 00038805
Shop #: WSC 91590
2 Faults Found:
01834 - Bulb for Side-Blinkers; Left (M18)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 65573 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.15 V
ON
ON
OFF
OFF
OFF
01835 - Bulb for Side-Blinkers; Right (M19)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 65573 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.15 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 5M AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D087B7N
Coding: 0013645
Shop #: WSC 01269 785 00200
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 036 0070
Coding: 0002022
VCID: 77D33FFD06D6651
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K6 920 873 A HW: 1K6 920 873 A
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0G8080142
Coding: 0007107
Shop #: WSC 00000 785 00200
VCID: 3041C4E1A338729
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4590K111140544
Coding: E9811F06001202000000
Shop #: WSC 12345 123 12345
VCID: 69F769854062C31
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T1V7903
VCID: FDDFADD5A4EACF1
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1610
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 005 0983
Coding: 0001077
VCID: 3851FCC14B48AA9
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.074 H07 1806
Shop #: WSC 00000 028 00001
VCID: 3449C8F157204E9
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 939006885103083F0004058FF0080A0488BC00
Shop #: WSC 12345 785 00200
VCID: 71C701E568B23B1
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0001076
VCID: 3957F9C57042B31
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: F4C988F197A08E9
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H13 0043
Revision: -----26S Serial number: VWZ4Z7K3129964
Coding: 0000040004
Shop #: WSC 00066 123 12345
VCID: 61E771A578528B1
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 116
Mileage: 65573 km
Time Indication: 0
Date: 2000.00.00
Time: 22:00:58
End ---------------------------------------------------------------------
07' GTI TFSI, APR ECU Upgrade, ABD Stage 2 Intake, APR 3.0" RSC Turboback Exhaust, Automaxx Coilovers, 18" OZ Ultraleggera wheels, RCD-510, Badgeless grille w/ filler, full tint, w/ side markers and mirror signals.
#2
Jack Shapiro E.P.E. VAS>ASE Extern VST-3/1 LAB (TECH INQUIRIES ARE TO BE IN WRITING )
7076062 NYS DMV SAE>NASTF>VW-Audi GEKO Authorized
European Parts Emporium/Performance --- Immobilizer Solutions LLC --------
Postadresse: 1001 State Route 17K Montgomery New York 12549 USA
vwemporium@aol.com -845-457-9808 TEL 9AM-5PM --------TAKE CONTROL OF WHAT YOU OWN!!!!!!
#3
Everything sir!
#4
#5
Use WD and repair manual with meter to properly measure the resistance of the bulbs and harness to controller to be in spec.
Verify correct bulbs and part #.
#6
Did SIDE BLINKER is really in your car? Usually when is in mirror, is not in front wing. If you recode Bordnetz for this, you might have SIDE BLINKER ERROR bulb. Check is available, because is strange - both bulb fu**** up in this same time.
Activate needle illumination in ALL MICRONAS cluster since 2004 up to 2010. Activate STAGING for all NEC cluster since 2008 even if not availabe in adaptation chanel.
#7
#8
Either compare to side that is without error or use the repair manual.
#9
#10
Your coding as posted:
A7 8D CF 29 40 04 15 00 47 14 00 00 00 14 00 00 00 18 F7 0B 640001
Normally MKV GTI/GLI/Jetta Vehicles do not have Side BLINKERS in the USA.
BYTE 02, Bit 6 Side Turn Signals Lights Installed
Current Coding for your BYTE 02 is: HEX CF, or Binary 1100 1111
It Should be HEX 8F, or Binary 1000 1111
Try that, and report back.
Rain Closing Windows, goF raeR, Aspherical Mirrors, Remote Windows, Amber Club
#11
Pssst how did that coding happen then?
God loves everyone
VCDS hates no backups.
#12
#13
For the record VCDS didn't induce this, you did.
And now you will do an auto-scan backup and post it so you have a record for the future right......?
#14
See the Coding Log found in: C:\Ross-Tech\VCDS\Debug
.. which will contain all of the modifications you made with VCDS on that PC - but is is much easier to save a complete scan BEFORE any modifications![]()
#15
