If you have vcds, it will guide you through setting the readiness.
#1
So I recently bought me a new (new to me at least) 2003 Volkswagen GTI 1.8t Tornado Redanyways... I am trying to pass emissions testing (State of Oregon) and get the car registered. So heres where the problems started...
I took it to DEQ to do an emissions test and it failed, the tech said that I needed to do a drive cycle to put all of the sensors in a ready state. I was working with radio and pulled the battery lead so that was probably why the sensors weren't ready. So I drove to Portland (50 mi round trip) and figured that would complete the drive cycle, then the CEL came on... P0420 Catalyst System Efficiency Below Threshold (Bank 1).
So I reset the CEL (this also resets the Drive Cycle) and drove it 100+ miles, all systems are ready except the following according to DEQ:
Catalyst: Incomplete
EGR System: Incomplete
How can I change these to the ready state and pass emissions?
#2
#4
I dont have VCDS.... I really need to invest in it. Could I use VCDS-lite to set the monitors to ready? I have a OBDII->USB device and could just download the shareware VCDS...
#5
#6
Turns out that someone put a test pipe on the car and took out the cat entirely. I was able to pass emissions like 5th time. I just ordered a wheel spacer so hopefully that should fix the P0420 I've been throwing.
2003 Tornado Red GTI 1.8t AWP 180 HP | Tiptronic 09A
100k | Cat-Delete | 2.5" Downpipe | Podi Boost Gauge | AM Air Filter | Bumpin Audio Sys
#7
#8
#9
#10
Spacer didn't work... I think I might need an angled one :/
#11
#12
I didn't want to spend the $40+ on the 42DD spacer, so I opted for a cheaper eBay 90 degree elbow spacer.
Like the one below... $19.25 ebay
Hopefully it works!
#13
Fingers crossed... but this thing seems to be working great now, just put 300 miles on it with no CEL. Seems to have done the trick!![]()
#14
16804/P0420/001056 - Catalyst System; Bank 1: Efficiency Below Threshold
Possible Causes
Leakage in Intake and/or Exhaust System
Catalyst faulty
Oxygen Sensor(s) faulty
Oxygen Sensor(s) Control faulty
Possible Solutions
Check Intake and Exhaust System for Leaks
Check Catalyst
Check Oxygen Sensor(s)
Check Oxygen Sensor(s) Control
Perform Oxygen Sensor(s) Aging Check
Special Notes
For 1.8T's experiencing this fault code, this thread may be useful: http://forums.vwvortex.com/zerothread?id=663057
#17
No Cat -> P0420 CEL ->-> Research -> 90 degree ebay o2 spacer (~$20) ->= Problem Solved
use the google my friends![]()
#18
Possible Causes
Catalyst faulty
Possible Solutions
Check Catalyst
AFTERMARKET DOWNPIPE WITH CAT DELETE
Special Notes
