VWVortex.com - Need help/advise on how to best get my wheels to work on my MK3 Jetta
    Results 1 to 10 of 10
    Thread: Need help/advise on how to best get my wheels to work on my MK3 Jetta
    Hybrid View
    1. Member BooglesMcGee's Avatar
      Jul 27th, 2009
      Minot, ND
      1994 MK3 Jetta GL
      04-25-2012 03:25 AM #1
      I have a set of ESM 009 type a replicas in 15x8 with an offset of 10. The tires I have are Nitto neo gen 205/50/15. My question is, what would be the best way to get these to work on my car? I'm going to have them on with some raceland coils, and I want to bring it down about an inch to an inch and a half from stock ride height. Am I in way over my head with this setup, or do you think I can pull it off with rolling and pulling the fenders and some fender flares? Or should I try to sell the tires that I have (brand new, never mounted) and get some 195/50/15 tires and stretch them? I want to keep the overall outer diameter as close to stock as possible. Anyway, here are some pics from the test fit I did on the front, haven't tested the back yet.
      View from straight above:
      The tires on them now are 195/45/15 yokohama s drives that are shot, so not going to run with them. Any help would be appreciated.
      "What monstrosities would walk the streets if some people's faces were as unfinished as their minds." Eric Hoffer
    2. Senior Member 87vr6's Avatar
      Jan 17th, 2002
      SLC snow life
      THE IY AWD BT 20TH and Ti edition RS4
      04-25-2012 05:20 AM #2
      Those pictures are with 195 width tires? lol. You should have researched before you bought. You're not going to make those "work" and by "work" i mean look halfway decent.
    3. Member BooglesMcGee's Avatar
      Jul 27th, 2009
      Minot, ND
      1994 MK3 Jetta GL
      04-25-2012 01:51 PM #3
      Quote Originally Posted by 87vr6 View Post
      Thanks for the negativity, does anyone have anything constructive or helpful to say?
      Sent from my iPod touch using Tapatalk
    4. Member VWGTI4fun's Avatar
      May 6th, 2009
      Santa Monica CA.
      1.8T Beetle, 02 XC70
      04-25-2012 06:47 PM #4
      You are going to have to roll the fenders
      I'm running 15x7 with 35mm offset (borbet type C)
      205 section width tires and they barely clear the fender on the front.
      A 15x8 rim with 10mm offset will be sticking out about an inch and half further.
      Around here some shops will roll the fenders for as little as $60
      maybe you can find something affordable, like that.
      [IMG][/IMG]
    5. Senior Member 87vr6's Avatar
      Jan 17th, 2002
      SLC snow life
      04-25-2012 07:15 PM #5
      Quote Originally Posted by BooglesMcGee View Post
      sorry if the truth hurts. You literally need to have sheet metal extended flares. Simply rolling them will not make them fit any better. You need wider fenders. Is that constructive enough?
    6. Member BooglesMcGee's Avatar
      Jul 27th, 2009
      Minot, ND
      1994 MK3 Jetta GL
      04-25-2012 08:38 PM #6
      Sorry, I was in a bad mood at the time, didn't mean to lash out at ya. Do you think it would be possible to get a second set of fenders, cut the metal out around the arches, and weld them to my existing fenders? Or maybe instead of folding the lip inward (the part that gets rolled up inside when rolling) maybe place cuts every inch or two and folding them outward, thus extending the arch, and then attaching fender flares to that? I think that would be the cheapest route, as I'm already into this for a bit of money, and want to throw as little at it as possible to try to make it work. If worst comes to worst, I may just try selling the wheels I have and get some 15x8 with a less aggressive offset.
      And VWGTI4fun, I plan on rolling the fenders. I have a friend that has access to one and he said he will do it for me. I'm going to try to get ahold of him on Friday and see what he thinks.
    7. Senior Member 87vr6's Avatar
      Jan 17th, 2002
      SLC snow life
      04-26-2012 04:47 AM #7
      I would do this. I know you said you were in for quite a bit of money, but to extend the fenders, which is done pretty much by the method you described is going to cost a pretty penny... Unless you're doing it yourself, but if not, expect 1000's... I inquired about a while ago to a shop that does phenomenal work (Ryan Miller in PA) and 3 years ago it was 2500...
      Compare this:
      To a stock MK4 jetta:
      Excellent work is pricey. Find new wheels, sell those, if they're 4x100 plenty of E30 BMW owners would like them
    8. Member BooglesMcGee's Avatar
      Jul 27th, 2009
      Minot, ND
      1994 MK3 Jetta GL
      04-26-2012 05:02 AM #8
      Thanks for the help and the info on where to look to sell these, but do you think that my cut/fold out method has a chance of working?
