VWVortex.com - One side lower on coilovers
    Results 1 to 5 of 5
    Thread: One side lower on coilovers
    1. 04-25-2012 11:00 AM #1
      Is there a reason why front right side is tucked under a fender while the left front isn't? I adjusted the coilovers to be the same before putting them in. Then tried shortening the left side even more but that only does little difference. Level ground and Racelands. 98 Passat V6 with 152k miles.
      Thanks fellas.
      Sent using flux capacitor.
    2. Member 18t papa's Avatar
      Dec 28th, 2009
      Orange County, NY
      '91 Passat 16V Variant, MK3 Supra Turbo, 1977 Jawa 350
      04-25-2012 02:38 PM #2
      My neuspeed springs sit slightly uneven, its because weight distribution left to right is not perfect. I'd say to adjust them slightly to get it even
      Long live the SCüMWAGON!
      IG: @captain_scum
    3. Member nolesfan's Avatar
      Mar 9th, 2011
      Nutley, NJ
      2013.5 GLI Autobahn
      04-30-2012 11:43 AM #3
      I'd say lower the high one a bit, and raise the low one a little. This should help get them closer. You may want to measure the height from center of the wheel to arch on both sides, then split the difference that way when raising/lowering.
    4. Member
      Jan 31st, 2012
      Everett, WA
      B5.5, Range Rover Classic
      04-30-2012 10:13 PM #4
      Have you tried sitting in the car or at least putting someone who wieghs the same and checking it?
    5. Member Steve in Chicago's Avatar
      Dec 13th, 2008
      Chicago, Illinois
      1999 Volkswagen Passat GLS
      05-01-2012 09:59 AM #5
      A science of vague assumptions based on debatable figures taken from inconclusive experiments and performed with instruments of problematic accuracy by persons of doubtful reliability and questionable mentality
