Results 1 to 6 of 6
Thread: Some silly new owner questions
  1. 04-25-2012 02:30 PM #1
    So, we are just a few days into the van and having read the manual pretty much cover to cover we still have a few questions:
    I just noticed that the van has a fixed radio antenna- does that mean that I have to take it off to go through a car wash? All of my recent cars have had either nubs or retracting power antennas- I don't want to lop it off in the wash...
    Also, is it possible to use the RSE + headphones AND play something else/stream music on the front deck? I'd love to plug the grommets into their media and still be able to have front seat (audio) entertainment.
    Related, I figured out how to put a single photo into the head unit display- is there a way to set up a screensaver that rotates through photos?
    Finally, I cinched down a pair of car seats in the back seat and found that they compressed the "leatherette" more than I'm accustomed to- I released them and added towels for padding. Even so, I'm a bit concerned that 3 more years of car seats will cause irreparable harm. If so, I guess, so be it, but if anyone has suggestions for protecting the seats I'd love to hear it!
    Cheers,
    Guy
    Are there any other cool hidden features that we should know about on an SE?
    Jun 27th, 2007
    58 Ragtop Bug, 2005 Passat Wagon, 2010 Routan SEL
    04-25-2012 03:25 PM #2
    Quote Originally Posted by GuyContinental View Post
    To be safe I would remove it, that is the biggest eyesore of the van, I just notices that the Siennas have the old CB antenna too.
    Yes, the rugrats can watch what they want with headphones and you can crank out to your favorite tunes
    One photo at a time and they won't scroll thru.
    I've had my daughters car seat cinched in for 1.5 years so far and every once in a while when the dog can't reach what she has dropped I uncork the seat give a nice wipe down and all seems good. We had two car seat cinched on our Passat for years and now I drive it and everything bounced back other than some rub marks, but in the van I bought super soft gray hand towels and have them on the contact points. Kohls, Bed Bath and Beyond, Marshalls are all good cheap places to get the towels.
    You don't have to hold the key over to start it, just a quick flip and let go.
    The hoods are aluminum.
    If you have the power rear gate there is a black rubber strip that is on the body that is by where the glass meets the body, that rubber strip is a sensor that can be used to re open the hatch rather than fumbling for the switch inside.
    You can lock out the power sliders by flipping the switch on the overhead console by the mirror (if you have power sliders)
    I'm sure there is more I'm forgetting, I'm sure others will chime in.
    1958 VW Ragtop Bug
    2005 VW Passat Wagon
    2010 VW Routan SEL
    Be sure to check out the Original Routan Dead Pedal Click Here
  3. Junior Member
    Mar 29th, 2011
    10' ROUTAN SE-RSE
    04-25-2012 05:42 PM #3
    Not sure if this was in the manual:
    Hold down the unlock on the key and the front windows will roll down.
    The driver side sliding door will not open when the gas door is open
  4. Member VWroutanvanman's Avatar
    Feb 12th, 2011
    Florida
    2010 Routan Norge SE w/RSE
    04-25-2012 11:43 PM #4
    Here's a list of things that can be programmed to your Routan http://forums.vwvortex.com/showthrea...hlight=key+fob
  5. Member Air_Cooled_Nut's Avatar
    Mar 15th, 2000
    Portland, Oregon
    2010 Routan SEL; '95 Jetta GL; '76 Riviera Bus; '72 Squareback; '06 Ducati SC 1000
    04-26-2012 11:19 AM #5
    Okay, for the record, you should be using a brush-less car wash. These won't lop off classic antennas since there are no whirrling brushes or drapes that will touch the vehicle. Brush systems are BAD for your paint! Stay away from them! Better yet, wash your vehicle by yourself because this way you will get closer to your vehicle and be able to spot dents, chips, and loose lug nuts
    95 Jetta GL 2.0L, chipped, intake, exhaust, compression, cam, CHE w/Peloquin, etc.,
    72 VW Squareback, rag top, 2.0L, parents original owners
    76 VW Riviera Bus, the family camper -- '02 Passat 1.8t & '13 Touareg Executive (wife's)
    06 Ducati Sport Classic 1000...only motorcycles can feed the need for speed
  6. Member VWroutanvanman's Avatar
    Feb 12th, 2011
    Florida
    04-28-2012 06:25 PM #6
    As far as the antenna goes, I keep the appropriate size wrench in the console and remove the antenna before I go into the car wash, and I install a bolt with an o-ring hand tight in the antenna socket to keep water out. The car wash puts quite a bit of stress on the antenna base (scary looking the way it gets whipped around, expect the thing to get yanked off the fender). And yes, the hand wash is better, but don't always have the time.
