Results 1 to 8 of 8
Thread: Engine Sound w/vid link
  1. Member Tutti57's Avatar
    Jun 20th, 2011
    Rochester, NY
    2006 Passat 2.0T and 2008 Touareg VR6
    04-25-2012 09:14 PM #1
    I know that the injectors make a clicking/tapping noise but am I imagining the lower pitch sound here? It doesn't seem so loud all of the time but I'm sensitive and paranoid.
    I have an intake too.
    http://m.youtube.com/watch?v=covelz2Up_Q
    2006 Passat 2.0T Tiptronic | Unitronic Stage 1+ | Rokkor Coil Overs | White Line Control Arm Bushings | BFI Tranny Mount | Nuespeed P-Flo Intake | Newsouth Boost Gauge | Rev D Diverter Valve | BSH PCV fix | eBay Climate Knobs | Autotech Exhaust | DDM HIDs | Stereo Upgrades | Bentley Manual | VCDS
    2008 Touareg VR6
  2. Member Tutti57's Avatar
    Jun 20th, 2011
    Rochester, NY
    04-26-2012 06:37 AM #2
    Just so you know, that video was taken near the front passenger side wheel.
    2008 Touareg VR6
  3. Member Tutti57's Avatar
    Jun 20th, 2011
    Rochester, NY
    04-28-2012 08:04 AM #3
    Bump-a-roo.
    2008 Touareg VR6
  4. Junior Member
    Apr 27th, 2012
    LI NY
    2008/VW/Passat 2.0t FSI
    04-28-2012 07:13 PM #4
    Hey, its my first post on here, but you need some extended footage, 13 sec of I can't tell you what the hell it is isn't helping you. Longer video, less moving around, more description of the sound you are looking for.
    Used to be a mechanic 10+ years ago and it sounds like when ppl used to tell me that their car was making this noise or that or doing this or that but it was really no description at all.
    Run the vid for a few min to let ppl distinguish the sound from the normal deisal sound.
  5. Moderator nater's Avatar
    Apr 10th, 2000
    Downingtown, PA
    2008 Passat 4Mo 3.6L Wagon, 98 VRt, 2010 Routan/Caravan :)
    04-30-2012 06:44 AM #5
    Almost sounds like an exhaust leak.
  6. Moderator nater's Avatar
    Apr 10th, 2000
    Downingtown, PA
    04-30-2012 07:20 AM #6
  7. Member Tutti57's Avatar
    Jun 20th, 2011
    Rochester, NY
    04-30-2012 08:54 AM #7
    Quote Originally Posted by nater View Post
    That's what I was thinking too. Maybe the dp flange is in its way out. Is there ever any warning with that or does it just bust and get loud?
    2008 Touareg VR6
  8. Member Tutti57's Avatar
    Jun 20th, 2011
    Rochester, NY
    10-14-2012 03:25 PM #8
    Bringing this guy back from the dead.
    Looks like it wasn't an exhaust leak since I replaced the turbo and the sound didn't go away after I bolted everything back up.
    Someone else posted a clip with this sound recently too but I don't know if it was ever diagnosed.
    I'm making a list of parts to replace this spring and am thinking it could be the cam chain tensioner. Should I add that to the list?
    2008 Touareg VR6
