Results 1 to 9 of 9
Thread: 83 gti no start- has spark and fuel HELP!!!!!
  1. 04-25-2012 09:57 PM #1
    I have a 83 gti that I have been having a really hard time getting started. I finally got spark, turned out I had the wrong distributor. Anyway now I have spark, car has fuel, cranks really strong, but still won't start. Any suggestions????
  2. Member vdubCorrado's Avatar
    Nov 8th, 2001
    Baltimore MD
    2013 Charger R/T - 91 Corrado - 92 Corrado VR6
    04-25-2012 10:10 PM #2
    Are you getting fuel past the CIS box or are you getting it on the way up?
  3. 04-26-2012 12:33 AM #3
    I smell it vat the cis box, not sure if it's getting past there or not. How can I check that?
  4. Member Erthan's Avatar
    Sep 9th, 2011
    Hellertown, Pa
    VW Truck 16v
    04-27-2012 01:05 PM #4
    did you put the cap on the right way?
    I woke up in a new Bugatti
    Aug 7th, 2006
    Northern NJ
    2003 ML320 / 1981 16v Sport Truck/ 97 Golf
    04-27-2012 03:47 PM #5
    You should be able to pull an injector out and place it in some sort of container and crank. You just want to verify you're getting gas out of the injectors. A helper would make it a bit easier.
    Seeing that you mentioned a new distributor I would rotate it in small increments and crank between each movement. Could be a timing issue at this point. It may kick over at some point during the rotation.
    Mar 31st, 2008
    PNW - Oregon
    04-27-2012 05:06 PM #6
    Quote Originally Posted by elomont View Post
    most of the time, that does nothing. the engine usually sucks air thru the now vacant injector hole and doesnt pull the air sensor plate up..
    the correct way to do this, is to lift the air sensor plate with a magnet, from the bolt head, and either jumper the fuel pump relay (easy) or have a buddy hit the key (even easier) and watch for fuel spray as the fuel pump comes on with the sensor plate lifted..
    Aug 7th, 2006
    Northern NJ
    04-27-2012 09:43 PM #7
    I once had all 4 of my injectors pulled out of my 16v and had them resting on a piece of cardboard so that I could see the spray and it worked. They did not spray right away, but after cranking for a bit all four emitted fuel and darkened the cardboard!
    You may be correct as related to the "correct" way to do it and how "most of the time, that does nothing", but this was my personal experience!
  8. 05-02-2012 11:43 AM #8
    Thanks for the advise, I got the engine to run, but it dies right away. My first issue was that my timing was way off. Now the engine starts, but dies right away. I'm gonna check for fuel delivery at this point to make sure it's getting enough fuel.
    Any other suggestions?
  9. Member VDub435's Avatar
    Jun 18th, 2009
    Garnerville, NY
    1988 Golf
    06-03-2012 12:06 PM #9
    I'm having the same problem as you, i havent gotten mine to start yet. how did you have to time it to get it to start?
