Results 1 to 4 of 4
Thread: Aba/Jh silicon hoses
  1. Member ((a.v.))mk-1's Avatar
    Dec 9th, 2010
    salt lake city, ut.
    1984 rabbit GTI, 95 jetta, 2011 yaris :)
    04-25-2012 11:03 PM #1
    Now that it's running great it's time to combat the heat, any body running Samco or like hoses on their swap? Which should I pull the trigger on?
    aww mah gawdz teh b0rk3n sahspenshun yoo roond et~
  2. Member keeton's Avatar
    Aug 15th, 2010
    Winston Salem, NC
    '84 Jetta, '84 Mustang 4.6 4V, '96 Mustang GT
    04-28-2012 10:28 AM #2
    You really shouldn't have any extra heat buildup if you did everything correctly and your cooling system is working correctly.
  3. Member ((a.v.))mk-1's Avatar
    Dec 9th, 2010
    salt lake city, ut.
    04-28-2012 11:32 AM #3
    I see, my radiator could be clogged or wrong hose to wrong connection piece, however I do like the look of them, and would still like to know which pieces to order. However, my fully built bottom end, driving habits, and 80 deg weather in April don't help the heat either.
  4. Member
    Mar 31st, 2008
    PNW - Oregon
    04-29-2012 02:13 AM #4
    Quote Originally Posted by ((a.v.))mk-1 View Post
    still tho, a VW cooling system, in good working condition, will cool the HOTTEST of hotrod engines no problem.. an aba with a JH head aint even much warmer than a stock engine, so a stock cooling system should be just fine.. if its not, then you have OTHER issues..
