Results 1 to 5 of 5
Thread: Boost Pressure issue?
  1. Member RcNdi's Avatar
    Apr 24th, 2011
    Charleston, WV
    2006 BMP GTi 6Spd (Mine) and 2011 Jetta 2.5 SE (Wifes)
    04-25-2012 11:19 PM #1
    I have thrown tons of money after this but cant solve it.
    I am only getting a peak of 14.X and holding around 13. I am APR stage 1 on a 2006 BPY 2.0T
    I have heard i should be seeing more like 18 peak and 15-16 hold.
    What i have tried so far...
    Made sure it was in APR 93 OCT Stage 1 Tune
    New intercooler pipes
    new wastegate
    new n75
    new (used 20K mile) K03 turbo ( mine did have shaft play)
    New Revision D (piston) diverter valve
    new BSH blockoff plate and catch can.
    It was pressure tested by the dealer to 2 Bar he said that was really high but if i am not mistaken i think that is only 13 psi due to natural atmosphere.
    I had logged it before changing the turbo but yet to have a chance to log since but before the turbo swap it lagged about 2 PSI behind requested boost.
    It also has no codes showing in VCDS.
    2006 GTI PKG2 6MT, APR S2+, Eurojet TBE, K&N intake, Solowerks Coils, and MORE
    VCDS/Vag-Com Available (Donations Accepted) (Kanawha County region of West Virginia)
  2. Member RcNdi's Avatar
    Apr 24th, 2011
    Charleston, WV
    04-28-2012 04:13 PM #2
    Please someone chime in with a idea.
    Jul 23rd, 2003
    St. Albans, WV
    07 Fahrenheit GTI APR Stage 1
    04-28-2012 09:57 PM #3
    Have you tried a different gauge? Does the car feel different? If you are reading with the vagcom are you converting it correctly. Just some things that could be an issue. Have you did a compression check on the engine. Are the injectors working properly. No fuel, No heat means low boost.
  4. Member
    Jul 23rd, 2003
    St. Albans, WV
    04-28-2012 10:13 PM #4
    By the way if the dealer pressure tested to 2bar. That is around 28 psi. Unless the gauge showed pressure on it before he started. So if he had no leaks at that pressure you should be good there.
  5. Member RcNdi's Avatar
    Apr 24th, 2011
    Charleston, WV
    04-30-2012 09:45 AM #5
    Thanks for the ideas I may be changing to another guage to see if my guage is a price of ****. And thanks for the correction on 2bar.
