#1
okay soo i have a 1997 golf k2 2.0l and i blew my tranny and bought a 02a tranny from a 96 paset vr6 what all do i need to put in what will i need to change? thanks![]()
big dreams and low bank acounts
#2
The Professor
Melbourne, FL
92 Corrado OBD2 ABA Powered by MS3Pro
M & L EFI Performance
Sandy Linfert 11/4/1991 - 5/13/2013
#3
You want an 020 trans, not 02A.
1998 GTI 2.0
1993 Jeep ZJ 4.0
World Automotive
#4
If you are looking to do the o2o to o2a swap here is a good list in a thread that I made:
http://forums.vwvortex.com/showthrea...2#post76995092
Also you need an o2a out of a 4cyl. Like a Corrado,
98 Jetta 2.0 w/ Megasquirt 3/3x fully sequential
ABA 16vT build thread
#6
You bought a passat VR6 trans? It won't bolt up. At all.
Firstly, you need a 020 code trans. From a 93-99 Jetta/Golf/GTI 2.0.
Second, you CAN use a 02a code trans, but it has to be from a 4 cylinder car. Like a corrado g60, or a passat 16v. It's stronger than the stock 020, shifts smoother, has cable linkage, etc.
If you want to make your 2.0 8v faster, read the thread below!
http://forums.vwvortex.com/showthrea...owerful-2.0-8v.
#7
im thinking he didnt actually buy the o2a trans, only said he did so it sounded like hes making moves..
o2a swap is not that simple even with the right o2a, u need to swap the pedals and get the brake booster for the hydraulic clutch and all the other **** mentioned and then some.
020+bolt kit+shim kit=decent setup thats plenty strong for the NA 2.0
