Results 1 to 5 of 5
Thread: Hitachi fuel pump question
  1. Member The Gerb's Avatar
    Mar 6th, 2012
    Roanoke, VA
    2006 GLI, 72 Super Beetle chopped(project)
    04-26-2012 12:20 AM #1
    I got a 06 GLI a lil over a week ago and i went to check the cam follower today but couldnt get the fuel pump un hooked. Its got a regular hose fitting and looks like a brake style banjo fitting. i cant seem to get the bolt out. has anyone had this same problem? The car has 129000 on it and im not sure if its ever been done. i hope someone can help me with this. i would have gotten pics but i dont have a mirror.
    My username used to be Slow MK3. But ive upgraded to a MK5 GLI so i changed my name.
    Sep 23rd, 2009
    Dallas, TX
    2007 Audi A3 2.0T
    04-26-2012 12:31 AM #2
    Quote Originally Posted by The Gerb View Post
    Yeah, the banjo fitting came on some of the earlier versions of the pump. It is a PITA because you have to take the fitting loose to pull the pump out. Later versions come with a "bamboo" fitting with a flexible rubber hose, so you only have to undo the one side to pull the pump. I think one of the DIY's floating around explains how to remove the banjo fitting...my pump doesn't have that one so I don't know for sure, sorry
  3. Member The Gerb's Avatar
    Mar 6th, 2012
    Roanoke, VA
    04-26-2012 12:46 AM #3
    hanks ill look around somemore. i searched some but couldnt find anything
  4. Member The Gerb's Avatar
    Mar 6th, 2012
    Roanoke, VA
    04-26-2012 12:56 AM #4
  5. Member Tutti57's Avatar
    Jun 20th, 2011
    Rochester, NY
    2006 Passat 2.0T and 2008 Touareg VR6
    04-27-2012 07:19 AM #5
    I have the banjo bolt to and made a little post on how I got mine off. Don't know how helpful it will be buy here it is.
    http://forums.vwvortex.com/showthrea...7#post74140687
    2006 Passat 2.0T Tiptronic | Unitronic Stage 1+ | Rokkor Coil Overs | White Line Control Arm Bushings | BFI Tranny Mount | Nuespeed P-Flo Intake | Newsouth Boost Gauge | Rev D Diverter Valve | BSH PCV fix | eBay Climate Knobs | Autotech Exhaust | DDM HIDs | Stereo Upgrades | Bentley Manual | VCDS
    2008 Touareg VR6
