Before you blow money at cheap no brand/bad brand parts at autozone (they do have some oem things but don't think a coil would be one, could be wrong.) I would spray test it first. Open garrage at night. Pull in car. Pop hood prop, dim lights motor still running. Spray coil and wire area once to detirmine where it is arching. It may be arching from a wire, or the coil. Even the rotor inside cap can arc I believe. You can open the distributor cap now and inspect the rotor. If it's burned, she's done.
1stvwparts.com
europartsdirect.com
mjmautohaus.com
ignore chineseautoparts.com
But back on topic. Any idea what a shop would charge to check and repair leaks in the turbo system? Im starting to think there is a turbo leak because it happens at peak boost and it feels like the car is switching from a 2.0t to a 2.0 back and forth 2-3 times a second. still fast as hell, just dont want the issue
