Results 1 to 7 of 7
Thread: Got my PIAA bulbs in but how to remove my passenger drl?
  1. Junior Member
    Apr 16th, 2012
    Southern California
    2012 Passat SE V6
    04-26-2012 02:54 AM #1
    Headlight and turn light are easy as hell, but passenger side drl is impossible unless you remove something? Where do I start?
    2012 Passat SE V6
    2008 Honda Accord Sedan
    2001 Chevy Camaro SS
  2. Member TDI Brad's Avatar
    Nov 12th, 2011
    SC
    2012 Passat TDI SEL
    04-26-2012 06:48 AM #2
    There is an access panel on the inside of the wheel well with one screw holding it in. I found going through there difficult but it can be done. Personally I suggest removing the fog light and getting at it that way. And if you are swapping the fog lights too then you'll already have it out. Hope this helps.
    Euro switch, 30% 3M nano ceramic tint, Chinese BiXenon headlights and LED tail lights, H&R springs, paddle shifter steering from V6, 20" Giovanna Kilis wheels, 225/35ZR20 Conti DWS tires
  3. Junior Member
    Feb 21st, 2012
    2012 VW Passat SE
    04-27-2012 01:29 AM #3
    what if you dont have fog lights hah? would it still be easier to take the covering off of where the fog lights would be? or go through that access panel
  4. Junior Member
    Apr 16th, 2012
    Southern California
    2012 Passat SE V6
    04-27-2012 01:53 AM #4
    No, you have to remove the wiper fluid. And it looks impossible to do unless you remove the headlight. Hmm..
    2012 Passat SE V6
  5. Junior Member shredX's Avatar
    Apr 18th, 2012
    ABQ, NM
    2012 Passat VR6 SEL Premium
    04-27-2012 06:32 AM #5
    I was able to snake my arm in there just like the driver side. The socket turns the opposite way.
    Good luck!
    '12 Passat VR6 SEL
    Jan 13th, 2004
    H-Town,TX
    04-27-2012 07:37 AM #6
    If you wanna access everything including fogs easily just remove the headlights, it takes all of 10 minutes to do very simple.
  7. Member TDI Brad's Avatar
    Nov 12th, 2011
    SC
    2012 Passat TDI SEL
    04-27-2012 07:56 AM #7
    Even if you don't have fog lights you can still remove the panel in the grill where are suppose to be to access DRLs and the wiper fluid take is not an issue then. Or if you feel like it do what the other guy said and remove the whole headlight.
