Results 1 to 21 of 21
Thread: Mk4 4motion VR6 24v turbo
  1. 04-26-2012 06:03 AM #1
    Hey guys and girls, just thought I would post a few pics of my MKGolf 4X4 turbo, specs are as follows:
    2.8 VR6 24V
    Uprated 6 puk clutch
    6 off 360cc/min injectors
    O2M 6 speed 4 wheel drive transmission with Haldex
    ATW chargecooler
    Devils own water/meth injection
    T34 .63 AR Turbo
    Coilovers
    R32 cat back exhaust
    AEM piggy back ecu
    Megasquirt, microsquirt ecu controlling fuel only
    All built and tuned by myself over the past five months
    Apr 24th, 2007
    Northern VA
    04-26-2012 05:03 PM #2
    I would love a 4wd turbo vr. That's awesome.
    #61 VRalliance
  3. Member pimS's Avatar
    Jan 7th, 2009
    Nearby Amsterdam
    96' VRT
    04-26-2012 05:10 PM #3
    Don't take this as negative but:
    Why spend bucket loads of money on a ECU, and then buy small chinese turbo +small injectors +small exhaust?
    DCA Facebook
    Build it, Run it, Break it, Fix it, Repeat!
  4. 04-27-2012 03:23 AM #4
    Quote Originally Posted by Vr6TurboTech View Post
    Thanks
  5. 04-27-2012 03:36 AM #5
    Quote Originally Posted by pimS View Post
    Who said I spent loads of money? What turbo and injectors would you suggest for the power I am running and the reason I have built this car?
  6. Member CTdubbin7's Avatar
    Apr 15th, 2009
    Bethlehem CT
    2000 gti 6262 Vrt
    04-27-2012 04:50 AM #6
    Quote Originally Posted by chaffe View Post
    I assume that all he means is,if you have the mechanical know how to get this far,why not put a larger turbo and injectors the first time around leaving you room to grow into it so to speak. I know I get used to the power level I have and then want more. But that bug might not have bitten you yet haha. Car is awesome
  7. 04-27-2012 06:05 AM #7
    Quote Originally Posted by CTdubbin7 View Post
    Cheers, It didnt come accross like that! The project was done on a budget and therefore I used second hand injectors etc etc, It is not the plan to run much more power than I have just now, mainly because It will cost a great deal more and would be a lot of work, I would need a better clutch, flywheel, fuel pump, ecu, pistons, rods before I even look at turbo's and injectors, that's just not economical for me. I went 2.8 24v to give me a head start in the first place, with a turbo I am happy enough on a std engine, with petrol at $11 a gallon (£1.50 a litre) here in the UK I think fuel economy has to play a small part!
  8. Member Norwegian-VR6's Avatar
    Feb 6th, 2002
    Norway
    96 Golf 3.0 VRT. 01 Golf V6 4Motion, 12 Skoda Superb 2,0 TDI avant
    04-28-2012 03:31 AM #8
    I have the same car as a daily, and I have found out that there isnt any tuner I know of that sells turbo software for the coilpack 24V VR6. I know VF sold supercharger software. I would love to throw a nice turbo for low boost. Is your turbo happy with boost over 5000 rpm or do you feel some power loss?
    Skoda Superb 2.0 TDI avant: Daily family car
    Golf MK3 12V Turbo. http://forums.vwvortex.com/showthrea...er-VR6-T/page6
    Golf V6 4Motion: Dailydriver
  9. 04-28-2012 04:08 AM #9
    Quote Originally Posted by Norwegian-VR6 View Post
    Hi, I am using AEM piggyback and a mega squirt ecu! This turbo doesn't make full boost until 4000, and pulls hardest 5500+, the rev limiter is the only thing that drops the power off
  10. 04-28-2012 02:49 PM #10
    hgp has sw for that one too
    R36T AWD 1100HP
    www.ktech.dk
  11. 04-28-2012 02:51 PM #11
    chaffe: i have to ask...why are you running both megasquit and aem fic?
    R36T AWD 1100HP
    www.ktech.dk
  12. 04-28-2012 04:14 PM #12
    Quote Originally Posted by VR6-GT42RS View Post
    LOL, a valid question my freind. Being a MK4 with ABS, traction control, drive by wire throttle etc I have to keep the OEM ecu plugged in and happy. I do all tuning myself and would not be happy paying someone to do it (there is no fun in that!) So AEM was the obvious choice to trick the lambda sensors on boost, trick the MAF voltage and retard timing, also AEM was used to control the injectors, this is where the problems started and I had a lot of bother fine tuning the AFR, it would stray all the time, the factory ECU would always try and correct no matter how I tuned the lambda voltages or injectors.
    The solution was to leave the AEM tricking the MAF, retarding timing on boost and emulating injectors as well as tricking the lambdas, and use megasquirt to soley control injectors, it works well, although quite complicated! And best of all i can tne it myself! the OEM knock sensing still works too
  13. 04-28-2012 04:20 PM #13
    This should help me to run some more boost!:
    Couldn't resist a little test!
  14. 05-02-2012 05:43 PM #14
    was out tuning tonight, took a little pic:
  15. 05-06-2012 12:35 PM #15
    So on your country you dont have tuners who can done custom ME7 tunes ??? Even on our small country Bulgaria there are two of them who can done that with great success.
    Here are two of their projects, Madness Motorsport Audi TT 3.2 quattro and TST-Racing Golf 4 with hybrid 3.3(build from 2.8 AQP) 4motion.
    http://www.youtube.com/watch?v=eEHFO7Pu1QE
    TT is with ME7.1.1 ECU, Golf is with ME7.1 i.e same ECU like car on this topic, both cars are 100% street and run high 10sek with trap speeds over 215km/h, thats on normal 98 European fuel what we have on every gass station
    And here is again Madness TT vs TST-Racing Golf 5 R32 Turbo (2008 year) with latest version ME7.1.1 CAN ECU
    http://www.youtube.com/watch?feature...&v=IBvROD4bGjk
  16. 09-16-2012 12:52 PM #16
    Bit of an update, dropping the compression, raising the boost, going for more power!
    Other than that the car is running well, making my own short runner inlet and have also converted the car the cable VR6 throttle body. Will be making the car completly stand alone management too on the megasquirt. I have enough fuel for 420bhp, the clutch and turbo may not do that though! But I want to keep the car quite sensible still with a usable power.
  17. 09-16-2012 01:57 PM #18
    Nice work on the flanges....did you make an Autcad or DXF drawing for that or are you selling any?
  18. 09-16-2012 03:23 PM #19
    Quote Originally Posted by viw28 View Post
    Cheers, no autocad prog, I just wrote a program on the Cnc mill at work. Sorry none for sale! I barely have enough time to make my own!
  19. 09-17-2012 02:43 AM #20
    Haha, know the feeling! Whereabouts in the UK are you?
  20. 09-17-2012 08:59 AM #21
    I'm up north mate, more pieces to the inlet manifold jigsaw:!
