VWVortex.com - Tightening Vent Windows
    Results 1 to 20 of 20
    Thread: Tightening Vent Windows
      Nov 30th, 2010
      Apple Valley, MN
      86 Cabriolet, 73 Super Beetle
      04-26-2012 07:38 AM #1
      I posted earlier that I tightened my vent windows, I received a couple PM's asking how so I figure I should make the available to all
      Anyways my drivers vent window would flop close going anything above 20mph, the passenger was great.
      When you open the window you will notice two holes in the bottom of the gasket. The green circle has the adjuster in it. Red circle is a mystery to me.
      Take a 4mm allen and find the adjuster. Righty tighty lefty loosey
      I've read that if you over tighten in it will crack a plastic piece... be careful
      dink and flicka
    2. Banned They_Call_Me_Bob's Avatar
      Mar 20th, 2006
      Washington DC
      04-26-2012 11:23 AM #2
      Just to contribute. That bolt is down there pretty far, you will need a longer allen wrench. 4mm worked, 5mm was too big (some other posts indicated a 5mm bolt was down there).
    3. Junior Member MissAnthropic's Avatar
      Jan 25th, 2011
      Richmond, Virginia
      '87 Cabriolet
      04-27-2012 12:39 AM #3
      Thank you thank you!!!!
    4. 04-29-2012 03:05 AM #4
      Great stuff! Thanks for sharing this info!
      Apr 16th, 2009
      Wild Wonderful Wv.
      1965 Beetle, 1987 Triple White, 1988 cabriolet, 1993 2dr Fox gl, 1999 Jetta GL
      04-29-2012 07:25 AM #5
      I need to do my drivers side but the top hinge is a lil loose from the door and the rubber seal is so brittle !
    6. Banned They_Call_Me_Bob's Avatar
      Mar 20th, 2006
      Washington DC
      04-29-2012 09:59 AM #6
      Quote Originally Posted by Beetle.freak View Post
      My top hinge was a little loose, much better after tightening the bottom hinge.
      As for the brittle seal, get some of this and apply it over and over and over. It won't fix any cracks but it will save what's left of the seal and plump them up a bit. Works wonders on b pillar seals.
      Gummi Pflege Stift
      Apr 16th, 2009
      Wild Wonderful Wv.
      04-29-2012 11:00 AM #7
      Thanks, I'll give it a try. Eventually I'd love to get all 4 window scrapers and replace the ratty looking windshield plastic chrome and I'm sure I'm gonna need em for the triple white when go to redo her !
    8. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      90, 92, 93 Cabriolet They own you.
      04-29-2012 10:45 PM #8
      Just so you can see what you are adjusting see number 1 in the pic,,,, warning too tight and you break the thing so easy does it.
      Grounds, Grounds, Grounds Replace them things.
      Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
      Another Useless Ground Thread
      HAVE YOU CHECKED THE FAQ's ABOVE..PAGE 3 Thread 75? Why bother no one else does.
      You can lead a user to a link, but you can't make them click.
    9. Member kamzcab86's Avatar
      Feb 13th, 2002
      Arizona
      1986 Cabriolet Best Seller; 1990 Vanagon Westfalia; 2016 Golf GTI S
      04-30-2012 01:15 AM #9
      Thanks for the reminder. My driver's vent window has been closing in direct correlation with speed for eons.
      Question for those in the know: Does tightening this gizmo change the degree to which the glass opens, or does it simply tighten things up? My window currently opens to a nice 45° and I don't want to lose that. My van's vents open to 90° and that angle is utterly useless, except for preventing bugs from hitting me in the face through the main window at 70mph.
      And: Cabby-Info'd!
      Cabby-Info.com -- Your online guide to VW Cabriolets/Rabbit Convertibles
      Old Blue's Blog -- The adventures of a 1990 Westfalia
      "Fashion is a waste of money that could be better spent on, say, maintaining your car." ~James May
    10. Member
      Nov 30th, 2010
      Apple Valley, MN
      04-30-2012 07:50 AM #10
      I"m pretty sure all it does is clamp down on the post labeled 15 in the image Brian posted. You should be able to open your window to what ever angle you wish... i think
      dink and flicka
    11. Banned They_Call_Me_Bob's Avatar
      Mar 20th, 2006
      Washington DC
      04-30-2012 07:54 AM #11
      Mine still opens to the full 45 and they now stay open until 60 ish. The pivot is just tighter, no loss in range of motion.
      Apr 16th, 2009
      Wild Wonderful Wv.
      04-30-2012 10:37 AM #12
      How are you guys/girls getting 60-70mph ?!?! Lol
    13. Member kamzcab86's Avatar
      Feb 13th, 2002
      Arizona
      04-30-2012 04:03 PM #13
      Quote Originally Posted by They_Call_Me_Bob View Post
      Excellent. I'll give it a go then.
      By placing proper force upon the accelerator pedal with one's right foot.
    14. Banned They_Call_Me_Bob's Avatar
      Mar 20th, 2006
      Washington DC
      04-30-2012 04:06 PM #14
      I guesstimate, as I am too lazy to fix my speedo! HA.
    15. Member h8Tr_'s Avatar
      Jul 23rd, 2008
      Miami Beach, FL
      10 VW CC, 88 VW Cabriolet
      05-02-2012 09:06 AM #15
      Awesome!!!!👍👍gonna go this this now
      '10 VW CC SPORT DSG
      '88 VW CABRIOLET 1.8L 5 SPD
    16. Member BoraVR's Avatar
      Mar 13th, 2005
      Toronto
      '87 MK1 Cabby, '08 B6 Passat
      05-05-2012 06:37 PM #16
      Just did this, worked great! Thanks for the post
      Mk1 Mayhem
      ______________
      VRSociety #142
    17. Banned They_Call_Me_Bob's Avatar
      Mar 20th, 2006
      Washington DC
      05-21-2012 09:51 AM #17
      As a shameful follow up and friendly reminder; don't over tighten the pivot in the door frame. I learned the hard way that it will indeed snap on you.
      However, the way it snapped surprised me so listen up. I was able to torque down the 4mm pivot inside the door pretty hard, without anything snapping. I thought I was in the clear and would enjoy vent window action up until 90 MPH. Well, after I tightened the pivot I went to close the window; POP! The friction was so high the window wasn't able to close and VW must have designed it such that the pivot gave before the window itself. It did not take much force at all for the pivot to snap, and it happened before I even knew it.
      So, what I learned is that the pivot may not necessarily break while you are torquing it down, but it is more likely it will snap when you go to close the window! Be careful!
      I will take some pics when I fix the part; for reference the part number is 171837455
    18. Member
      Nov 30th, 2010
      Apple Valley, MN
      05-22-2012 07:07 AM #18
      Well if you really want your windows open while going 90 heres an idea from MissAnthropic "I've been folding the drivers mirror back to hold it open"
      I have done this on the highway. It works really well. You loose being able to see out of the mirror but they are pretty much worthless anyhow.
      dink and flicka
    19. Member
      Mar 17th, 2012
      Rochester, NH
      1989 Cabriolet
      07-13-2012 12:07 AM #19
      worked great! over tightened the pass side though.. now i gotta find a new piece
    20. Member benrk's Avatar
      Feb 19th, 2012
      Winnipeg, MB, CDN
      '82 BMW 633CSi, '85 VW Cabrio, '94 Volvo 850, '04 Mazda 6
      07-14-2012 12:13 AM #20
      Quote Originally Posted by hyperlightboards48 View Post
      Worthless??? My chrome mirror buying wallet has a different opinion
