Results 1 to 2 of 2
Thread: Painting an Exterior Door
  1. 04-26-2012 10:24 AM #1
    I have an exterior door which faded, so I decided to repaint it. I sanded the door down to remove loose paint, bought the correct exterior paint and painted it. I believe I used latex paint this time.
    It didn't take long for the paint bubble and blister. The door does face the sun most of the day.
    So I re-sanded it and re-painted it. I bought oil based paint, at the reccomendation of the hardware store, to try to avoid the blistering. No dice. It didn't last but a few weeks before it started blistering.
    It appears that the primer underneath is holding tight.
    Any thoughts on what I'm doing wrong or what I should try?
    Chuck
  2. Member Rockhead261's Avatar
    Jan 5th, 2004
    Brewster, New York
    '75 Eldorado vert, '13 Sierra Denali CC D/A, '11 Outback 3.6R
    04-26-2012 11:24 AM #2
    I use Wil-Bond on anything I paint. I used it on the undercarriage of my truck before I undercoated and the stuff never even chipped. I've even used it on surfaces that are supposedly unpaintable (i.e. vinyl window trim) with excellent results.
    At this point I would tell you to sand/remove as much paint as possible before prepping with this stuff, maybe a couple of times to really etch the surface good.
    Rockhead
    '75 Eldorado 'vert, '13 Sierra Denali 2500 CC D/A, '11 Outback 3.6R, '12 FLHTCUI
    Quote Originally Posted by minibike hero
    Alternately, you could set his house on fire. Tall grass + leaking fluids + Lucas = plausible alibi.
    Necrospam!
