Results 1 to 7 of 7
Thread: Thermostat removal and install. Help please
  1. Member asap617's Avatar
    Jun 24th, 2010
    Around Boston
    1991 VW GTI 16v(RIP), 2002 VW GTI VR6(RIP),A4 V6, Mk4 Jetta Vr6
    04-26-2012 10:40 AM #1
    I have a b6 3.0. I trying to locate and change the thermostat without having to remove the bumper etc. Does anyone know or have changed this out on theirs? Can you give me a small walk through or point me in the right direction to find a DIY write up?
    Any help is appreciated.
    Go fast or don't go at all
  2. Member 98blueb5's Avatar
    May 11th, 2008
    NH
    B6 A4 3.0
    04-26-2012 12:00 PM #2
    Found this quote on another forum
    "good luck with the v6 i replaced my t-stat without removing more than the covers and the acc belt, took 7 hours and was a bitch, then i had to do it again because when i bolted everything up again i somehow droped the o ring.the v6 have the t-stat behind the t-belt so its reallty hard."
    http://www.audiforums.com/forum/audi...ng-much-60917/
    This guys saying it took him 3 hours...
    http://www.audi-forums.com/b6-forum/...hermostat.html
    I am now praying i never have to replace mine... If you know a good shop, just take it to them...
  3. Member asap617's Avatar
    Jun 24th, 2010
    Around Boston
    04-26-2012 12:03 PM #3
    Quote Originally Posted by 98blueb5 View Post
    Yup i saw the same thing on Audizine..Arrrg. i really dont wanna bring it to a shop. Thanks Man.
  4. Member 98blueb5's Avatar
    May 11th, 2008
    NH
    B6 A4 3.0
    04-26-2012 12:04 PM #4
    Just noticed you are "around boston".. If your willing to drive to Manchester, give Reflex Tuning a call. Doug and Heather should be able to help you out.. Wiked good people, great prices; always willing to help..
  5. Member asap617's Avatar
    Jun 24th, 2010
    Around Boston
    04-26-2012 03:00 PM #5
    Funny you mentioned them. I just sent them an email about it doing a complete timing job since the whole front end would be coming off anyways.
    Thanks again
  6. 04-27-2012 11:47 AM #6
    Not sure about a 3.0; but on my 1.8t I was able to do this pretty easily by just removing the intake manifold and working from the top of the motor.
    I'll see if I can find a diagram of the 3.0 and figure out an easier way; regardless some things will probably have to come out for you to change it if you want an easy job.
  7. Member zeroboy's Avatar
    Sep 3rd, 2005
    Audi
    02' S6 Atlas grey / 02' S6 Silver
    04-28-2012 02:37 AM #7
    I can tell you it's pretty tight with the front clip OFF. You could put the rad support in a sort of 50% service position. Remove front bumper cover, Just loosen it all up and tilt it way forward. I did mine with the timing belt- and I could imagine doing a T-stat by itself if I had to, but I wonder how much time you'd save. It's not hard to put the front in service position, accesory belt off is easy from there- then PS pulley and you can get a look at it.
    It's tight.
