Results 1 to 6 of 6
Thread: carbonio intake
  1. Junior Member 96mk3gti91's Avatar
    Feb 10th, 2009
    Nebraska
    2009 VW Tiguan S
    04-26-2012 12:18 PM #1
    im putting on the stage 2 pipe and its not fitting correctly. Has anyone else had problems?
  2. Member GlfSprtCT1's Avatar
    Feb 8th, 2002
    East Hartford, CT
    2011 CSG GTI
    04-26-2012 03:55 PM #2
    yup.. known issue. search is your friend, but ill tell you what i did.
    The mounting tab on the underside of the tube?... used a dremel and elongated the hole so i cld get more adjustment out of it. i can sneak my index finger between the pipe and brake resv. now, no vibrations.
    another tip is to have the intake tab in front of , rather than behind, the metal tab it mounts to.
    2011 GTI / APR K04-Carbonio stg1/2 intake-APR catted dp-Magnaflow catback-APR intercooler-Audi S3 shifter-Podi boost tap/boost gauge-034 Motorsports engine/trans mounts (street density)-DXD stg2 daily-H&R coilovers-APR 27mm rear swaybar/Whiteline adj. end links-vcds coding tweeks-Tinted oem tails-HPA 6 piston bbk/80a subframe mount
    Follow on instagram @glfsprtct1
  3. Member Slayer's Avatar
    Aug 8th, 2000
    Windham CT
    2008.5 GTI w/TSI motor, 1995 GTI Vr6
    04-26-2012 04:08 PM #3
    yeah just put it on the front side of that tab. Mine's been like that for like a year and a half
    Check out my Garage build thread - 08.5 GTI 2.0T TSI, APR stage2, APR intercooler, 42DD 3" Catless Downpipe, Autotech 3" Exhaust, Full Carbonio intake, AWE DV relocation, BSH Motormounts, Coolingmist CMGS stage2 Meth injection, Dieselgeek Shortshifter, Southbend Stage2 Endurance clutch, Forge Shift knob, Euro LED tails, Koni Coilovers, Miro STP3 19x8.5 rims, General Exclaim 225/35/19 Tires
  4. Junior Member 96mk3gti91's Avatar
    Feb 10th, 2009
    Nebraska
    2009 VW Tiguan S
    04-27-2012 02:30 AM #4
    about the vibrations. did you only feel them in the gas pedal under acceleration?
  5. Member GlfSprtCT1's Avatar
    Feb 8th, 2002
    East Hartford, CT
    2011 CSG GTI
    04-27-2012 05:17 PM #5
    Quote Originally Posted by 96mk3gti91 View Post
    mostly, yes
  6. Junior Member 96mk3gti91's Avatar
    Feb 10th, 2009
    Nebraska
    2009 VW Tiguan S
    04-27-2012 09:38 PM #6
    ok cool just making sure it wasnt just me imagining things
