Results 1 to 6 of 6
Thread: can a malfunctioning cam position sensor cause a backfire?
  1. 04-26-2012 04:01 PM #1
    just bought a mkIV gti. the guy i bought it from said he had to replace/rebuild the intake manifold because the motor backfired and went through the intake. i ran the codes and it comes up with a bad cam position sensor, secondary air pump and the O2 sensor looks a bit off though no codes for it.
    does this sound legit or could there be something else going on?
    btw, hi!
  2. Member GTIVRon's Avatar
    Jul 24th, 2009
    Keller, Texas
    92 Corrado SLC, '12 Golf R
    04-27-2012 10:57 AM #2
    Negative ghost rider. A bad cam sensor just retards timing by like 20*.
    2002.5 Jetta 1.8T - TOTALED (dodging deer)
    2002.5 24v GTI - TOTALED (rear-ended by a Jeep)
    1992 Corrado SLC - The toy & DD
    2012 Golf R - The weekender
  3. 04-27-2012 11:55 AM #3
    well i've noticed that the car has a problem with cold starts. i'll turn the key and it will crank a bit and sometimes start and sometimes not. i have to cycle the key off and then attempt to start it again. usually, when this happens, it will be a weak start and takes a few seconds for the idle to level out.
    i'm thinking there's a timing issue.
  4. Member Scotty_2.0's Avatar
    Jan 13th, 2005
    North York, Ont.
    Mk2 GTI VR6... .......................Mk5 Rabbit 2.5
    04-27-2012 02:04 PM #4
    Sound more like a coolant temp sensor failing. Does the exhaust smoke or smell like fuel?
    /// VRSociety Member #298 /// Mk2 Milita-VR6 Battalion-2dr Regiment /// Instagram @scottyvr6 ///
    My 2.9L BVH build and the machine shop #%@- up that almost ruined it all.
  5. 04-28-2012 02:36 AM #5
    it doesn't smoke. haven't noticed excessive smell of fuel/richness. he has a magnaflow catback on it so it's hard to say.
    would the coolant temp sensor throw a CEL? no codes for that one.
  6. Member Scotty_2.0's Avatar
    Jan 13th, 2005
    North York, Ont.
    04-28-2012 09:54 AM #6
    Quote Originally Posted by RonPopeil View Post
    Not always, no.
