Results 1 to 10 of 10
Thread: Strange humming noise
    May 25th, 2010
    San Diego, CA
    2003 GLI
    04-26-2012 04:40 PM #1
    I am hoping you guys can help me diagnose this or at least where to begin. I have been hearing a sort of humming noise when the car is running. It is sort of a background humming and I can hear it more when I am at idle and it's more quiet. The humming noise is consistent whenever the car is running. When I am at idle I can even hear the humming noise change pitch for a few seconds then return back. It almost sounds like it is coming from the back of the car but I could be wrong. Sound almost sounds like a pump or something. It is really annoying me, esp knowing that something is not right. Anyone have ANY idea?
  2. Junior Member
    Feb 12th, 2012
    Where the Navy sends me...
    '03 Jetta GLI, '93 Corrado SLC
    04-26-2012 05:24 PM #2
    Can you hear it when you stand outside the car? If its coming from the rear of the car, the obvious culprit is the fuel pump. Either it's going bad or something in that assembly is not working correctly.
    -Holmes
    People are always surprised that my car smells of crayons
    May 25th, 2010
    San Diego, CA
    2003 GLI
    04-26-2012 05:54 PM #3
    Thanks for the reply. I haven't really noticed it from the outside then again I haven't RELLY tried. One thing I did forget to mention was when I turn off the car and if I twist the key back as if I was about to crank the car I can hear the same noise for about 1 second. I can make it go off and on about two or three times the same way by twisting the key back. I was kinda thinking fuel pump too...
  4. Member
    May 25th, 2010
    San Diego, CA
    2003 GLI
    04-26-2012 07:20 PM #4
  5. Junior Member
    Feb 12th, 2012
    04-26-2012 08:16 PM #5
    Then yes, it is the fuel pump. When ou turn the key to the on position before starting it, the fuel pump will turn on to bump up the fuel pressure in before you try to start it. But, just because you hear it doesn't mean that something is wrong.
    -Holmes
  6. Member
    May 25th, 2010
    San Diego, CA
    2003 GLI
    04-26-2012 09:37 PM #6
    Thanks for the reply. Only this is now I REALLY hear it. It's now a constant humming noise. I am getting the same feedback though, that it might be a bad fuel pump. I just want to me sure before I go out and buy a new fuel pump.
    May 25th, 2010
    San Diego, CA
    2003 GLI
    04-26-2012 11:28 PM #7
    Anyone have any input on this Meyle Fuel Pump that ESC sells for $133? (esc part#2207853). I'm not trying break the bank.
    May 25th, 2010
    San Diego, CA
    2003 GLI
    06-01-2012 09:13 PM #8
    I forgot to update this thread. Yes it was the fuel pump! Thanks again to those who replied.
  9. Member jlsgli89-03's Avatar
    Aug 25th, 2003
    Suffolk, Virginia
    2003 GLI ,1994 Jetta GL.
    06-02-2012 10:35 AM #9
    So how did the Job go.How long did it take you and was it a PITA ?
  10. Member
    May 25th, 2010
    San Diego, CA
    2003 GLI
    06-07-2012 02:15 AM #10
    actually had my local mechanic do the swap. He charged me a whopping $30 which I GLADLY paid!
