Results 1 to 5 of 5
Thread: Puncture in my R-Line's self-sealing $230 Conti tire.
    Apr 20th, 2011
    Southeast Florida
    2012 VW CC R-Line w/DSG
    04-26-2012 05:31 PM #1
    I didn't really understand the concept of self-sealing tires, so when I noticed my right front tire falling a little behind in pressure (28 vs 33psi), I noticed a screw in the middle of the tread. I took it to a tire guy to 'patch' and came back an hour later for the results. He says they discovered the self sealing ability so they didn't patch the tire. Instead, they say they "peeled away the area" and removed the screw, then re-set the 'goo' back in place ($30). The pressure seemed to be holding but after a week, the pressure has fallen back to the same as the others (about 33psi). In time, I expect it to fall below the other three.
    Does anyone have experience with nails or screws in these $230 tires? I think I'm screwed (pun intended). Does self-sealing mean it gets you to the next gas station, or does self sealing mean you drive over a nail and not worry for the remaining life of the tire?
    I suppose I can try to use the tire warranty, unless I voided it by having a dweeb try to fix it.
    Larry
    2012 CC R-Line, DSG (stock)
  2. Member MrRline's Avatar
    Apr 6th, 2010
    Buckeye, Arizona
    2010 VW CC R-line, 2012 GLI Autobahn
    04-26-2012 05:38 PM #2
    The conti seal in the tire is pretty much nothing more than that fix a flat stuff you can get at places.. It's about 8 lbs of this stuff coated on the inside of the tire. It's meant to seal small punctures such as a nail in the tire. It of course isn't full proof if there's not enough of the substance around the puncture area or the puncture is too large then it may not be able to seal it properly. I'm sure I had a nail or two during my experience with them and I didn't have a problem the entire year I ran them. If you have a warranty try to get it replaced if you don't then consider purchasing a new tire. If you don't want to pay for the tires then i'd suggest taking a look into a new brand of tire.
    Right now i'm running the hankook ventus v12's and i'm loving them.
    2010 CC R-line. 5% tint all around,Debadged, Euro Clear Corners, 8k Hid's, LED TAG lights, K&N Filter, VAG-COM windows, H&R springs, Led interior lights, Apr Stage 1 Carbonio Intake
    2012 Jetta GLI Autobahn- Stock
    15.18 @ 93.44 now time for upgrades.
  3. Member wh1te09gti's Avatar
    Oct 12th, 2009
    West Milford, NJ
    '12 Urano CC R-Line 6MT( GIAC stg.2),White Benz C300 4matic (hers)
    04-28-2012 08:52 AM #3
    I dont like the idea of self sealing tires. Once my go bad im replacing them with regular ones.
    Mar 10th, 2009
    2006 Passat 2.0t 6mt
    04-28-2012 11:21 PM #4
    To bad I don't live in Florida anymore. I would give you a free Conti Seal.
  5. Member de_bklyn's Avatar
    Jan 15th, 2011
    Brooklyn
    C7 A6 2.0T, C5 A6 Avant 3.0
    04-29-2012 08:58 AM #5
    I had the same experience (punctured conti) exactly 1 year ago. 5000+ miles later, no issues to report - the tire has held up pretty well.
    2013 A6 2.0T Quattro
    2004 A6 Avant 3.0L Quattro | Depo projector headlights, 6000k HID fogs,35% tint, Pioneer x940bt nav/head-unit, ST Coils, .....
