Results 1 to 4 of 4
Thread: body work questions for a nuub
    May 16th, 2004
    1986 16v Rocco
    04-27-2012 06:43 AM #1
    I'm doing some body work for the first time. I have a few blemishes in the car
    one is in the driver door behind the mirror its a crease like something thin hit it or like something dropped on it there. and then the other side has some rust spots i'm removing but the metal is deformed a little from something its just bumpy hard to describe but it has valleys i need to fill
    anyway since these are not just dungs what do i use to fill them i'm not looking for showroom here or i would replace the door which i might do later. i'm just painting the car flat black and want it not to be complete crap.
    I heard never use bondo ok fine there are so many other brands and types. I heard something about bondo with glass i dunno some are better for light dings other for heavy. I would rather not have to use 3-4 types of fillers also where can i find the filler you recommend.
    Dec 1st, 2011
    Louisville, KY
    08 GTI
    04-27-2012 06:59 AM #2
    Any body filler will outlive the car if applied to a properly prepared surface
    and is kept sealed up away from the elements. That includes "Bondo" brand.
    Most do prefer other brands, but mainly because of workability.
    I like "Rage Extreme" because it's easier sanding. But any will actually work.
    For small dings you may want a spot putty, not a lacquer based one that relies on drying but
    a spot putty that uses a hardener & chemically cures.
    I like several of them including "Metalglaze" &"Iceing"
    Those putties are real thin and runny and are for filling scratches & pin holes
    and used for a final skim coat over fillers. they're perfect for small dings.
    And they sand easier than regular body fillers. Great for a final coat.
    But you do have to prime over them like regular body fillers before paint.
    May 16th, 2004
    1986 16v Rocco
    04-27-2012 08:17 AM #3
    i can find bondo in any auto parts store. what about the others.
    I also heard to much hardener will make it not last long either
  4. Junior Member vwtuner810's Avatar
    Mar 8th, 2010
    Westminster
    03 VW GTI
    05-09-2012 07:56 PM #4
    to much harnder causes pin holes and bad adhision...
