Results 1 to 15 of 15
Thread: RI State Inspection
  1. Member infiniteecho's Avatar
    Apr 7th, 2009
    Boston, MA
    09 335xi 6MT, 13 Golf RS
    04-27-2012 08:34 AM #1
    Since we've swapped the motor in my car, I suspect I'll have issues passing inspection in RI.
    Emissions are good, I have no warning lights or anything like that, however the VIN of the ECU doesn't match the VIN of the body of the car.
    Does anyone know if this will pose an issue in RI?
    If so, does anyone have a friend at a shop that would be interested in helping me out with a sticker? Would be willing to compensate in or a shoot of your car.
    Thanks in advance to anyone who can help.
    IMS built UM tuned Golf RS.
  2. Member 1.8TBEOUT's Avatar
    Jun 13th, 2002
    mattapan ma
    84 jetta coupe 1.8t, 98 passat 1.8t pc-16,04 audi S4 6mt, 92 lt1 vette coupe
    04-28-2012 07:58 AM #2
    not sure about ri, but you should check if they have a referral program like ma. in ma if the pid values of your pcm arent the same as last years inspection it can fail you and refers you to a state ran inspection site to investigate (thinking you used another car for the test). if they dont have a program like that the obd test most likely just checks readiness status and cel state and if no codes and readiness is complete you're good. i dont think its a viloation to have another cars computer, people buy used computers all the time. in ma engine swaps are legal if you use the emissions equipment, it tests for the year of the engine instead of the car, but the swap has to use newer engine on older car, not vice versa.
  3. Senior Member thewhitsnpt's Avatar
    Mar 20th, 2002
    Newport,RI
    Mk3 Jetta 1.8t,2012 Passat
    04-28-2012 08:38 AM #3
    Non-matching will be an issue in an honest garage inspection. Any chance of swapping original ecu in just for inspection?
    RIP Alexi One of the good guys
    broke.status
    OSD
    NEK
  4. Member JonahD_1985's Avatar
    Jan 4th, 2011
    1997 Jetta GLS
    04-28-2012 08:51 AM #4
    Well if he went from a 2.0 to a VR6 he would have to swap ECUs. And if the original ECU crapped out on him that be the issue in doing that...My guess would be if you had some sort of paperwork showing that the ECU was switched you'd be ok.
  5. Member infiniteecho's Avatar
    Apr 7th, 2009
    Boston, MA
    04-28-2012 10:24 AM #5
    Quote Originally Posted by jvdub24vvr6 View Post
    try T&T Auto in Tiverton
    Could you PM me a contact there?
    Quote Originally Posted by thewhitsnpt View Post
    The car would not run with the original ECU, which is long gone at this point anyway. We can likely spoof the VIN in the ECU to match what's on the car. Just trying to avoid the extra programming time if I can find someone to toss me a sticker.
  6. Junior Member choppeR32's Avatar
    Apr 24th, 2010
    Rhode Island
    MKIV BMP .:R32
    05-13-2012 05:03 PM #6
    Hey Jesse, I always thought you were from MA. Where in RI are you? The place I go only checks if you have no CEL, and emissions are good. Located in Pawtucket if interested. Also wondering if you have all UM options available for my R? Love your ride dude!
  7. Member infiniteecho's Avatar
    Apr 7th, 2009
    Boston, MA
    05-18-2012 12:00 PM #7
    Quote Originally Posted by choppeR32 View Post
    I am just having UM match the VIN to the Body. Not worth this hassle.
    Which year R do you have? There are a couple different options depending on which gen you've got.
    EDIT: read your profile. There are some options, launch control, flat foot shifting, big cams, etc for the MK4
  8. Member Marc1987's Avatar
    Jan 23rd, 2010
    Westerly, RI
    2000 jetta gl
    05-18-2012 12:03 PM #8
    They rarely check the ecu vin man, they obviously know you swapped because when they run your car, it says 2.0 originally. They won't give you a problem, if they so, my friend does it in westerly and won't hassle you for ecu. Good luck bud.
    Sent from my r00ted payph0ne using Tapatalk 2
  9. Member infiniteecho's Avatar
    Apr 7th, 2009
    Boston, MA
    05-18-2012 12:10 PM #9
    Quote Originally Posted by Marc1987 View Post
    My car was a 3.2 before.
    Now running a 3.6 with FSI. Someone was likely doing a very thorough job. Can't fault them for that.
  10. Member Marc1987's Avatar
    Jan 23rd, 2010
    Westerly, RI
    2000 jetta gl
    05-18-2012 12:25 PM #10
    Oic, well regardless, you get what I'm saying lol
  11. Junior Member choppeR32's Avatar
    Apr 24th, 2010
    Rhode Island
    MKIV BMP .:R32
    05-19-2012 08:34 AM #11
    Quote Originally Posted by infiniteecho View Post
    Sorry man, I should've been a little more specific. I was asking about software tuning. So you have all options for that then? I was gonna talk to Jorge down at Premier Automotive, but I was curious if you were closer to me? I'm up in Burrillville.
  12. Member infiniteecho's Avatar
    Apr 7th, 2009
    Boston, MA
    05-19-2012 05:27 PM #12
    I am in Boston, actually.
    Not sure if that is closer for you or not. Normally I'd offer a ride in the R36 for incentive, but I just dropped it off for the VIN fix and some more goodies.
  13. Junior Member choppeR32's Avatar
    Apr 24th, 2010
    Rhode Island
    MKIV BMP .:R32
    05-19-2012 07:46 PM #13
    I just might wait for my tune if I can get a ride in that beast. HAHA! I was confused about your location, that's why I asked. Let me know when you get your ride back!
  14. Member infiniteecho's Avatar
    Apr 7th, 2009
    Boston, MA
    05-19-2012 07:47 PM #14
    Should be mid June.
    The car is registered at my property in RI. But I live full time in Boston. Have an MA registered car too. Just too lazy to move the R up to MA.
  15. Member
    Dec 5th, 2010
    Bristol, RI
    MkIII golf 2.0, mkIII Jetta vr6, mkIV Jetta 2.0 (205k and climbing), 1973 Standard Beetle
    05-19-2012 11:41 PM #15
    I can get that passed for you of you don't mind going to Smithfield I have a hookup with inspections. If you've got no codes or your car is year 2000 or under itll pass with flying colors. I've helped a few people out with inspections, pm me for details
    I've seen more Corvette wheels on Volkswagens than I have Corvettes
    Proud owner of a rusty 8v mkII and a 73 standard bug!
