Results 1 to 8 of 8
Thread: 04 VW Beetle - ASR/ESP Question
  1. 04-27-2012 08:51 AM #1
    I have been gifted an 04 Beetle that we had the transmission rebuilt by a local shop and as part of the process, I installed a new/rebuilt drive axle (Raxles) on the passenger side, and redid the front brakes with new pads and rotors. Now that all that has been completed, when I go out a test spin, the ASR light begins flashing at ~20 mph and the brakes begin trying to adjust for wheel spin which isn't actually happening. Then the light will go off intermittently and then re-engage. I checked both wheel speed sensors with a ohm meter and they read ~1000 ohms which seems to be in range. I brushed off both sensors a little. What or where should I look next?
    I can turn off the ASR with the ESP switch and it seems to behave.
    As far as the car itself goes, it seems to have a fair amount of torque and seems a little squirrelly when you get into the accelerator...is it safe to assume this is the nature of the car? You may see this post in a few other areas...I wasn't really sure where it fit.
    Thanks.
    Mar 6th, 2002
    Morris Plains/Parsippany, NJ
    1998 GTI 2.0
    04-27-2012 09:19 AM #2
    You need to get a scan tool capable of reading measuring blocks (datastream) out of the ABS module. VCDS is probably your best bet. Watch the wheel speed values while driving.
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
  3. 04-27-2012 12:38 PM #3
    VCDS Scanners. New to me so where should I start? A quick internet search came up with ross-tech. Are the scanners pretty brand specific or are there any that I could use with VW and Toyota for example.
    Thanks
  4. Member
    Mar 6th, 2002
    1998 GTI 2.0
    04-27-2012 01:56 PM #4
    www.ross-tech.com is the only place to get VCDS. Anywhere else is a pirated version/clone.
    The VCDS interface requires a Windows PC to operate. Personally, I use a Windows 7 tablet for portability purposes, but a laptop will work as well. A desktop will also work, but the portability aspect is gone.
    As far as VW/Audi, the software is as capable as the dealership tool, as long as you get the right interface for the vehicle(s) you're working on (HEX-CAN interfaces will work on all VAG cars 1996-2012). It will also do generic OBDII on most vehicles as well, the exception being cars using the VPW protocol, such as some GM or Ford applications.
    If you want near OE-capability with Toyota, there are a few options, but all are well over $1,000. PM me if you want info on that.
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
  5. Member greyhare's Avatar
    Dec 23rd, 2003
    Corvallis, OR
    '96 Jetta, '78 Rabbit, '79 GMC 3/4T 4x4, 2013 BMW F700GS
    04-27-2012 03:27 PM #5
  6. 05-19-2012 07:01 PM #6
    Ok, so I have purchased the VCDS package from Ross Tech and it looks like I am not getting any readings from either of the front wheel speed sensors. Is there a common ground for these? Is there a proper or better way to clean them? Or....
    Mar 6th, 2002
    1998 GTI 2.0
    05-19-2012 09:25 PM #7
    Cool
    Do a full auto-scan. When it completes, click the "copy" button, then reply to this thread and hit "paste". That will put the full scan in the thread. Let's start with that, so we can see exactly what this beast is made of.
    If you haven't played with the auto-scan function yet, here's a vid that explains it pretty well:
    http://www.youtube.com/watch?v=RCBt6d42-Fc
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
  8. 05-20-2012 08:48 AM #8
    This is a copy of the original scan that I ran and then I cleared the codes to "start fresh". The second scan is from this morning after a short lap around the neighborhood.
    Thanks for taking a look.
    S
    Sunday,06,May,2012,20:14:54:50820
    VCDS Version: Release 11.11.3 (x64)
    Data version: 20120401
    Chassis Type: 1Y - VW New Beetle Cab
    Scan: 01 02 03 08 15 17 19 22 25 26 29 35 37 39 46 54 56 65 75
    VIN: 3VWCD31Y24M337714 Mileage: 172890km/107428miles
    Address 01: Engine Labels: 06A-906-032-AWV.lbl
    Part No: 06A 906 032 PS
    Component: 1.8l 5VT NBC AG6G 5107
    Coding: 00004
    Shop #: WSC 00066
    VCID: 7EF9C5347AEC549
    3VWCD31Y24M337714 VWZ5Z0D0217114
    3 Faults Found:
    17608 - Boost Pressure Control Valve (N249)
    P1200 - 35-00 - Mechanical Malfunction
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-00 -
    16685 - Cylinder 1
    P0301 - 35-00 - Misfire Detected
    Readiness: 0000 0001
    Address 02: Auto Trans Labels: 09G-927-750.lbl
    Part No: 09G 927 750 P
    Component: AQ 250 6F 0387
    Coding: 0000008
    Shop #: WSC 00000 000 00000
    VCID: 3E7905346A6C949
    No fault code found.
    Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
    Part No: 1C0 907 379 M
    Component: ESP FRONT MK60 0102
    Coding: 0019970
    Shop #: WSC 00066 000 00000
    VCID: 346D271C54204E9
    2 Faults Found:
    00668 - Supply Voltage Terminal 30
    008 - Implausible Signal - Intermittent
    01164 - ESP Operation
    Address 15: Airbags Labels: 1T0-909-605.lbl
    Part No: 6Q0 909 605 AF
    Component: 01 AIRBAG VW71 0609
    Coding: 0012337
    VCID: 7BFFCC2039FE411
    Part No: 1C0 959 339 A
    Component: BF-Gewichtsens. 004 0004
    2 Faults Found:
    00591 - Seat Belt Switch; Driver (E24)
    006 - Short to Plus - Intermittent
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Address 17: Instruments Labels: 1C0-920-x4x.lbl
    Part No: 1C0 920 951 N
    Component: KOMBI+WEGFAHRS. M73 V02
    Coding: 11234
    Shop #: WSC 00000
    VCID: 2C5D3F7CDC10169
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN V022
    Coding: 00006
    Shop #: WSC 00066
    VCID: F0E56B0CB0B8B29
    Address 26: Auto Roof Labels: 1Y0-959-255-HYD.lbl
    Part No: 1Y0 959 255
    Component: VSG NBC 2604
    VCID: FDFB4238A7EACF1
    2 Faults Found:
    02000 - Switch Position
    02461 - Position Sensor for Right Linkage Flap Position Sensor (G443)
    009 - Open or Short to Ground
    Address 29: Left Light Labels: 7M3-907-391-29.lbl
    Part No: 7M3 907 391
    Component: EVG GDL + AutoLWR 0003
    Coding: 00006
    Shop #: WSC 00066
    VCID: F4ED671CC4A08E9
    2 Faults Found:
    01539 - Headlights Not Adjusted
    35-00 - -
    01771 - Control Module for Headlight Range (J431)
    47-10 - No Communications or Incorrectly Connected - Intermittent
    Address 39: Right Light Labels: 7M3-907-391-39.lbl
    Coding: 00006
    Shop #: WSC 00066
    3 Faults Found:
    01345 - Ignition Module for HID Headlamp (N195)
    27-10 - Implausible Signal - Intermittent
    01533 - Terminal 56 (High Beams)
    32-10 - Resistance too High - Intermittent
    00546 - Data wiring faulty
    Address 46: Central Conv. Labels: 1C0-959-799.lbl
    Part No: 1C0 959 799 G
    Component: 6J Komfortgerát HLO 0004
    Coding: 00256
    Shop #: WSC 00066
    VCID: 3B7F0C20297E811
    Subsystem 1 - Part No: 1Y1959801C
    Component: 6J Tõrsteuer.FS KLO 0005
    Subsystem 2 - Part No: 1Y1959802D
    Component: Tõrsteuer.BF KLO 0005
    Subsystem 3 - Part No: 1Y0959811
    Component: 6J Tõrsteuer.HL KLO 0001
    Subsystem 4 - Part No: 1Y0959812
    Component: 6J Tõrsteuer.HR KLO 0001
    4 Faults Found:
    00932 - Electric Window Motor; Drivers Side (V147)
    62-10 - No or Incorrect Adjustment - Intermittent
    01359 - Internal Central Locking Switch; Passenger Side (E198)
    00933 - Electric Window Motor; Passenger Side (V148)
    00935 - Electric Window Motor; Rear Right (V27)
    Address 56: Radio Labels: 1J0-035-18x-56.lbl
    Part No: 1C0 035 196 H
    Component: RADIO DE2 0004
    Coding: 06031
    Shop #: WSC 00066
    VCID: 244DD75CB4C0DE9
    1 Fault Found:
    07-10 - Signal too Low - Intermittent
    End ---------------------------------------------------------------------
    Sunday,20,May,2012,08:42:14:50820
    VIN: 3VWCD31Y24M337714 Mileage: 172900km/107435miles
    Coding: 00004
    Shop #: WSC 00066
    Readiness: 0010 1101
    Coding: 0000008
    Coding: 0019970
    2 Faults Found:
    Coding: 0012337
    2 Faults Found:
    Coding: 11234
    Shop #: WSC 00000
    Coding: 00006
    Shop #: WSC 00066
    2 Faults Found:
    Coding: 00006
    Shop #: WSC 00066
    2 Faults Found:
    35-00 - -
    Coding: 00006
    Shop #: WSC 00066
    3 Faults Found:
    Coding: 00256
    Shop #: WSC 00066
    4 Faults Found:
    Coding: 06031
    Shop #: WSC 00066
    1 Fault Found:
