Results 1 to 2 of 2
Thread: VCDS Newbie - Baseline scan feedback
  1. n00b
    Mar 9th, 2011
    SoNJ
    '09 CC Sport - 2.0L 6 sp. - APR Stage 1 ECU
    04-27-2012 11:33 AM #1
    After 49,500 miles of driving pleasure, I've taken a leap of faith and decided to keep my '09 CC Sport for another few years. To help reduce out-of-warrantee maint costs, I bought a Micro-CAN interface (Ross-Tech direct - promptly delivered yesterday), downloaded VCDS last night and ran a full scan. The entire process was quick and easy - thanks Ross-Tech!
    Thursday,26,April,2012,19:52:55:01710
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Shade Tree Mod Shop
    Chassis Type: 3C0
    Scan: 01 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 52 53 56 62 65
    72 77
    VIN: WVWNL73CX9E533646
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    0F-Digital Radio -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    1C-Position Sensing -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    65-Tire Pressure -- Status: OK 0000
    77-Telephone -- Status: Malfunction 0010
    Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
    Part No SW: 06J 906 026 AF HW: 06J 906 026 AF
    Component: MED17.5 TFSI 2,0 3318
    Revision: AAH03--- Serial number: VWZCZ000000000
    Coding: 0404010A18070160
    Shop #: WSC 05314 000 00000
    VCID: 6EFD1540798C249
    1 Fault Found:
    000545 - Angle Sensor 2 for Throttle (G188)
    P0221 - 000 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 3
    Mileage: 79365 km
    Time Indication: 0
    Date: 2103.14.28
    Time: 13:24:26
    Freeze Frame:
    RPM: 1830 /min
    Load: 9.4 %
    Speed: 37.0 km/h
    Temperature: 60.0°C
    Temperature: 27.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 14.224 V
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
    Part No SW: 3C0 614 109 P HW: 3C0 614 109 P
    Component: J104 C4 440 V2 0011
    Revision: --025--- Serial number: 00000786166835
    Coding: 0000373
    Shop #: WSC 05311 000 00000
    VCID: 2B7BDC548A1E111
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 3
    Fault Frequency: 8
    Reset counter: 177
    Mileage: 79365 km
    Time Indication: 0
    Date: 2103.14.28
    Time: 13:24:27
    Freeze Frame:
    Speed: 36.0 km/h
    Hex Value: 0x00D5
    Voltage: 14.25 V
    Bin. Bits: 00011111
    Count: 217
    Hex Value: 0x0000
    Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
    Part No SW: 3C8 907 336 E HW: 3C8 907 336 E
    Component: Climatic 120 0102
    Revision: 00004001
    Coding: 0000000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Climatic A01001
    ROD: EV_Climatic_VW46.rod
    VCID: 2F43C84476066D1
    No fault code found.
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
    Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
    Component: Bordnetz-SG H54 2602
    Revision: 00H54000 Serial number: 00000008898832
    Coding: F1848F8B40041A0047970F00170000000028FF475C40017C17 0000000000
    Shop #: WSC 05124 000 00000
    VCID: 334BC434522E491
    Subsystem 1 - Part No: 3C8 955 119 Labels: 1KX-955-119.CLB
    Component: Wischer 200908 022 0602
    Coding: 00046997
    Shop #: WSC 05124
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 171008 054 0402
    Coding: 00209133
    Shop #: WSC 05124
    1 Fault Found:
    02382 - Sensor for Light Detection (G399)
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 147
    Mileage: 78159 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 14.15 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
    Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
    Component: SDAR SIRIUS H07 0150
    Revision: 00000000 Serial number: AUZ4Z7H0411112
    Coding: 0000000
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 HW: 5N0 959 655
    Component: J234__313 VW10 HI 1815
    Revision: 19013000 Serial number: 0039BPLE2VM9
    Coding: 0012595
    VCID: FAD5A910B5C4F89
    Part No: 3C8 959 339
    Component: BF-Gewichtsens. 001 0003
    Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
    Part No SW: 3C0 953 549 AK HW: 3C0 953 549 AK
    Component: J0527 0025
    Revision: 00030000 Serial number: 3C5953507CP
    Coding: 0000511
    VCID: 75CF3A2C1CDA171
    Subsystem 1 - Part No: 3C8 959 537
    Component: E221__MFL-TAP H2ÿ 0021
    Coding: 00000226
    Shop #: WSC 00000
    Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
    Part No SW: 3C8 920 970 B HW: 3C8 920 970 B
    Component: KOMBI H19 0023
    Serial number: 00000000000000
    Coding: 240F00
    Shop #: WSC 05311 115 00000
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
    ROD: EV_Kombi_UDS_VDD_RM09_VW46.rod
    VCID: 2B7BDC54421E111
    Address 19: CAN Gateway Labels: 3C0-907-530.lbl
    Part No SW: 3C0 907 530 L HW: 3C0 907 951
    Component: J533__Gateway H13 0152
    Revision: H13 Serial number: 3300P08A020B55
    Coding: F980FF07001702009002
    Shop #: WSC 08212 444 52603
    VCID: 2A75D95085E4089
    Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
    Part No SW: 3C8 919 965 HW: 3C8 919 965
    Component: Kompass 001 0001
    Revision: 00001000 Serial number: 1614128T05CC02
    Coding: 0000002
    VCID: F5CFBA2C9CDA971
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 AK HW: 3C0 959 433 AK
    Component: IMMO 051 0383
    Revision: 00051000 Serial number: VWZCZ000000000
    Shop #: WSC 08219 444 84049
    VCID: 73CB043412AE091
    Part No: 3C0 905 861 H
    Component: ELV 028 0380
    3C0905861H ELV 028 0380
    Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
    Part No SW: 3C8 959 760 HW: 3C8 959 760
    Component: J810 0801
    Revision: 00002000 Serial number: 00000000000000
    Coding: 0000001
    VCID: F2C58130EDB4809
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
    Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
    Component: J386 TUER-SG FT 1533
    Revision: 71009005 Serial number: 00000509288912
    Coding: 0001463
    VCID: 40A19BF81398E29
    Address 44: Steering Assist Labels: 5N1-909-144.clb
    Part No SW: 5N1 909 144 G HW: 5N1 909 148 F
    Component: J500__APA-BS KL.074 0401
    Revision: 1AH02234 Serial number: 00081970399702
    Coding: 0000258
    VCID: 364DFD20415C5C9
    Address 46: Central Conv. Labels: 3C0-959-433-46.clb
    Component: KSG PQ46 RDK 051 0221
    Coding: 13910F8001862E521204141FF08A8F0E085C01
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
    Component: J387 TUER-SG BT 1533
    Revision: 71009005 Serial number: 00000888888916
    Coding: 0001462
    VCID: 41A79EFC1892EB1
    Address 53: Parking Brake Labels: 5N0-907-801.clb
    Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
    Component: J540 EPB3 VW-10498 0003
    Revision: 009 Serial number: 00000000161381
    Coding: 0000057
    VCID: 287123589BE83A9
    Address 56: Radio Labels: None
    Part No SW: 3C8 035 180 A HW: 3C8 035 180 A
    Component: Radio PM6 025 0046
    Revision: 00025000 Serial number: VWZ5Z7H2269928
    Coding: 0040401
    VCID: 20613B78F3D8C29
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 3C8 959 703 B HW: 1K0 959 795 Q
    Component: J388 TUER-SG HL 0309
    Revision: 43004101 Serial number: 00000000637210
    Coding: 0001168
    VCID: 3147CE3CA8327B1
    Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
    Component: RDK 0450
    Coding: 0100101
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 3C8 959 704 B HW: 1K0 959 794 Q
    Component: J388 TUER-SG HR 0309
    Revision: 43004101 Serial number: 00000000657616
    Coding: 0001168
    VCID: 3245C130AD34409
    Address 77: Telephone (J738) Labels: 1K8-035-730.clb
    Part No SW: 1K8 051 730 A HW: 1K8 051 730 A
    Component: Telefon H01 5200
    Revision: 00001000 Serial number: 20389520021727
    Coding: 412120
    VCID: 256F2A6C2CFA271
    1 Fault Found:
    03426 - Left Audio Channel
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 244
    Mileage: 58016 km
    Time Indication: 0
    Date: 2031.14.07
    Time: 08:57:19
    End ---------------------------------------------------------------------
    Before clearing the faults and re-scanning, I'm hoping to get some feedback on the faults.
    Feb 25th, 2012
    Miami, FL
    BPY VW GTI
    04-28-2012 10:11 AM #2
    Intermittent codes are just that, intermittent. When a 'fault' is seen it has to meet a threshold in order to trigger a MIL, but are still stored for trouble shooting etc. Do a throttle body alignment and clear the codes. Then enjoy your car.
