Results 1 to 26 of 26
Thread: Brake bleeding down to a science + track day pics.
  1. Member Jamaican_tuner's Avatar
    Aug 3rd, 2004
    South FL
    2004 VW .:R32
    04-27-2012 12:04 PM #1
    I have seen feedback from people that have used the brake bleed (using Motiv bleeder) DIY posted by Anthony some years ago that even after following the process as documented they still have poor pedal feel. I was one of them.
    I believe I have found the solution... have done it twice on my car and would like someone else to
    follow these steps and report feedback.
    The focus of my findings: The ever mysterious subject of cycling the ABS pump to perform a full bleed. There are many posts discussing it but none that I could find that fully explain how to use it to get the brakes 100%.
    Here is the procedure I followed:
    1- Drive car and do several aggressive stops (I did several 60mph to 30mph stops).
    2- Park car in garage or workspace in preparation for bleed
    3- Connect with Vagcom and connect to Brake and then Output tests
    4- Execute the first output test which activates the ABS pump (I activated for 8 seconds then stopped).
    5- Throw car up on jacks stands then follow the Brake Bleed DIY from start to finish. Note that through steps 4 reservoir is untouched bleeder not yet unboxed and all I am doing is the output test.
    I did this twice last week in preparation for a track day. Since I had two large cans of OEM brake fluid and since it is cheaper than the Motul RBF 600 I figured I could experiment.
    So with my street pad brake setup (hawk HPS) I followed the above procedure. Gained an inch of extra brake pedal feel!!
    Two days before the track day I swapped to new rotors and new race pads, drove around for 30 mins doing some aggressive braking then pulled in to the garage for bleeding. This time with Motul RBF 600. Followed the same process as describe above and had truly mind blowing brake performance (albeit in the rain) at the track logging over 100 on track miles across 4 sessions.
    Need someone to follow this procedure and report back your findings
    Track Day pics
  2. Member niles's Avatar
    Aug 6th, 2009
    Fairhaven, MA
    MKIVR32
    04-27-2012 01:14 PM #2
    When I get around to doing mine I'll try this out.
  3. Member rajuncajun37's Avatar
    Apr 25th, 2008
    New Orleans
    2011 FORD .:Raptor
    04-27-2012 01:28 PM #3
    Great information and and awesome pictures. We love seeing the Golf R32 on a track with expensive luxury cars!
    *R32 1518*, biggest head ever to fit in a GOLF!
    Congrats, turd burglar.
  4. Member Jamaican_tuner's Avatar
    Aug 3rd, 2004
    South FL
    2004 VW .:R32
    04-27-2012 01:59 PM #4
    Quote Originally Posted by rajuncajun37 View Post
    Got this pic from one of the club regulars. This is a pic of the intermediate run group on a Dry day
  5. Junior Member
    Feb 17th, 2012
    Boone, NC
    2004 .:Reflex Silver
    04-27-2012 03:58 PM #5
    Did you do the clutch as well? They share the same reservoir , no? If you did, did it improve the feel?
    Cheers
    aw
    04 .:Reflex
  6. Member Jamaican_tuner's Avatar
    Aug 3rd, 2004
    South FL
    2004 VW .:R32
    04-27-2012 04:10 PM #6
    Quote Originally Posted by adubya View Post
    Cheers
    aw
    I did not do the clutch.
  7. Member SpclAgentD's Avatar
    Oct 16th, 2001
    Sacramento, CA
    MkIV BMP R32, MkII GLI, '05 R6
    04-27-2012 04:11 PM #7
    I'd try it if I had a Vagcom. I gotta change my fluid anyway...
    FS: One 225-40/18 Nexxen N3000 Tire | Netgear Rangemax Dual Band Wireless-N DSL Modem/Router (DGND3300v2) | MkII Jetta 16v OEM Taillights | MkII ABD Racing CIS-E Intake Pipe (Not CAI)
  8. Member niles's Avatar
    Aug 6th, 2009
    Fairhaven, MA
    MKIVR32
    05-04-2012 01:17 PM #8
    Did mine yesterday, didn't gain much feel (although it wasn't bad to begin with) in the brake pedal but my clutch feels better. also found out one of my bleeders in the rear was stripped (Dude at the local autozone gave me a bleeder off a reman caliper for free though )
    running the output test for abs pump bleeding is listed on ross-tech's website as well.
    http://www.ross-tech.com/vag-com/cars/absbleeding.html
  9. Member Jamaican_tuner's Avatar
    Aug 3rd, 2004
    South FL
    2004 VW .:R32
    05-04-2012 01:46 PM #9
    Quote Originally Posted by niles View Post
  10. 05-05-2012 06:49 AM #10
    Couple of Q's -
    1) Why does RossTech say the wheels can't be touching the ground?
    2) What would happen if you did steps 1-4 but didn't then bleed the brakes?
    Ta
    MkIV R32 Turbo - VR6 Specialists (Spec to come at a later date when its all done)
  11. Member lil_kano's Avatar
    Apr 10th, 2007
    Coral Springs, Fl
    '04 RS .:R32 (Cloth), '02 Jetta TDI - R.I.P, '85 Scirocco - gone
    05-05-2012 10:09 PM #11
    Hey bro I'd like to give this a try. I need to bleed my brakes anyway. May be sometime at the end of the month we can meet up and try it out. I need to buy some fluid.
    Plus you can check out my new setup!
  12. Member schmuck's Avatar
    Jun 21st, 2002
    naptown
    04 dbp r32, 98 gti vr6
    05-05-2012 10:48 PM #12
    I will try it next time I bleed mine as well. I have tried variations of this before, but with the motive attached.
  13. Member BIG DUB's Avatar
    Feb 13th, 2001
    MD/VA/DC Area
    1980 turboed moped
    05-06-2012 12:22 AM #13
    I'll have to give it a try
  14. Member mfbmike's Avatar
    Feb 5th, 2011
    305 Miami, FL
    2008 CW R32, 1983 CW Rabbit LS
    05-06-2012 01:33 AM #14
    Homestead.
    I need to get out there and run my R around some time.
    Holy Milltek.
    Tarmacs cut it close.
    Miami Vase
    Cams A Make Her Dance
  15. Member BIG DUB's Avatar
    Feb 13th, 2001
    MD/VA/DC Area
    1980 turboed moped
    05-06-2012 09:59 PM #15
    Diy worked like a charm
  16. Member
    Oct 29th, 2008
    Boynton Beach, FL
    2004 BMP R32
    05-06-2012 10:44 PM #16
    Quote Originally Posted by Jamaican_tuner View Post
    I have the same issue.
    That seems to be what is missing between the way it was before & after bleeding. The brakes don't have the same feel they originally had before bleeding, & the comment about pedal position is accurate.
    Quote Originally Posted by Toffs View Post
    Couple of Q's -
    Ta
    The air wouldn't be expelled & would then try to find the highest point in the system it can reach.
    "Being in space was great, I had plenty of time to rub one out, which in space is great, but after a while it's like living in a snow globe" -Peter Griffin
    "You could whore yourself out to 1,000 fat chicks for $50 apiece. Or 50 really fat chicks for $1,000. What? Don't look at me like that. Fat chicks need love too. But, they got to pay." -Glenn Quagmire
  17. Member Jamaican_tuner's Avatar
    Aug 3rd, 2004
    South FL
    2004 VW .:R32
    05-09-2012 12:13 PM #17
    Quote Originally Posted by BIG DUB View Post
    As in the Brake bleed DIY or the ABS output test + the brake bleed DIY?
    What changes have you noted in pedal feel?
  18. Member Jamaican_tuner's Avatar
    Aug 3rd, 2004
    South FL
    2004 VW .:R32
    05-09-2012 12:14 PM #18
    Quote Originally Posted by CaptainQualude View Post
    If or when you try this procedure please report back your findings.
  19. Member Jamaican_tuner's Avatar
    Aug 3rd, 2004
    South FL
    2004 VW .:R32
    05-09-2012 12:15 PM #19
    Quote Originally Posted by lil_kano View Post
    Deal
  20. 05-09-2012 01:52 PM #20
    Sorry to sound thick, I'm kinda lost on whats the procedure being described in this thread:
    Please set me straight, this is how I'm reading into it so far
    1) go out and drive like a nutter and get the ABS to come on a few times
    2) connect up vagcom and activate the ABS test (no bleeding going on)
    3) disconnect vagcom.
    4) hook up a pressure bleeder and bleed brakes as normal one wheel at a time
    5) enjoy a much better brake pedal...
    Is that correct?
  21. Member Jamaican_tuner's Avatar
    Aug 3rd, 2004
    South FL
    2004 VW .:R32
    05-09-2012 02:14 PM #21
    Quote Originally Posted by Gti Fly View Post
    Is that correct?
    Yes
    This might all be possible by skipping step one but since I did it both times I added it to the procedure.
  22. 05-09-2012 02:23 PM #22
    Yes
    Many thanks
  23. 05-09-2012 03:08 PM #23
    Lol Fly, YOU woulnd't miss that step !
  24. Banned ThatVdub's Avatar
    May 28th, 2010
    Jax, FL
    Golf R
    05-09-2012 03:44 PM #24
    from my memory, which isn't too trustworthy at this age...
    supposed to press the brake hard, activate vag-com, it pushes up your foot, iirc.. and then you bleed when it says too...
    that way led to my firm pedal feel, firmer than the brake bleed alone.
  25. Member
    Oct 29th, 2008
    Boynton Beach, FL
    2004 BMP R32
    05-09-2012 04:26 PM #25
    Will do. It should be pretty soon. I picked up a set of Speed Bleeders a while back to try & solve the issue, so will be tossing those on also.
  26. 05-09-2012 04:50 PM #26
