Results 1 to 13 of 13
Thread: B&g 44k
  1. 04-27-2012 12:56 PM #1
    Hi guys,
    My 06 2.0t FSI has 80K miles on the clock, and I just had a a rather large and expensive service done on it yesterday. When I picked up the car, the dealer recommended that I could run a bottle of B&G 44k in my next tank of gas. It would aparently get rid of alot of carbon build-ups on the injectors and elsewhere.
    Does anyone have any experience with this product? if so, good/bad?
  2. Member low_passat's Avatar
    Sep 11th, 2010
    Goodyear, AZ
    04-27-2012 01:49 PM #2
    It may help clean the fuel injectors, but it won't do anything for the carbon build up on the valves since these engines are direct injection. The fuel is sprayed into the combustion chamber and never touches the valves.
    2007 Candy White/Black Passat 2.0T Wolfsburg Edition| APR Stage 2+ | APR HPFP | Forge WINtake | S3 Intercooler | B&B 3" Turbo-Back Exhaust | Dogbone Insert | FK Silverline+ Coilovers | Front Lip Spoiler/Hi-Def Sideskirts | Votex Trunk Lip Spoiler | R-Line Fog Grilles | Clear Corners | HID Kit - low beams & fogs | RCD-510 | Podi Boost gauge | R-Line Pedals | GTI Steering Wheel |
  3. 04-27-2012 01:51 PM #3
    yea that's true... Given that info, do you think it is a waste?
  4. Member low_passat's Avatar
    Sep 11th, 2010
    Goodyear, AZ
    04-27-2012 01:57 PM #4
    It's not a bad idea to run a fuel injector cleaner once in a while, so it's not a complete waste.
  5. 04-27-2012 02:01 PM #5
    ok. I have never done it, so maybe I will then
  6. Member
    May 10th, 2010
    North Jersey
    08 Passat wagon 2.0T 6MT (current). Past: 02 Golf TDI, Dark Beige 88.5 Camry V6 5MT, AE82 Corolla
    04-27-2012 02:40 PM #6
    BG 44k is good, but expensive.
    a bottle of Redline SI-1 is just as good... for half the price.
    2008 Passat wagon, 2.0T 6MT with mods
    Other Rides:
    - 2013 Cannondale CAADX-6
    - 2010 Specialized Secteur Elite
    - 2009 Specialized Rockhopper Comp 29-er
  7. 04-27-2012 03:02 PM #7
    yeah. Just bought a can. 28 buckaroos
  8. 04-27-2012 03:07 PM #8
    So there were no direct instructions. Do I add it at a quarter of a tank and then fill up or whats the best way? Add it to half a tank of gas for higher concentration?
  9. 04-27-2012 03:07 PM #9
    I started using bg 44k last year after being recommended by dealership. I now use it about every 5000 miles on my b6 and cayenne. I run it about 2 weeks before getting oil change. I purchase multiple cans at a time on eBay to get price closer to 15 a can. Seems to be good stuff.
    b6 2.0t 6m/t ATE slotted rotors Vmaxx coils S5 LED Headlamps S5 Reps 19x8 Toyo Proxy4's 5% Llumar Votex Lip B&B 3in DP
    PepperWagen ATE slotted rotors 22x10 Kohan's Yoko Spec X's 5% Llumar Euro turns
  10. 04-27-2012 03:09 PM #10
    Quote Originally Posted by joakim6945 View Post
    I put it in before I fill up and then run that tank till its about 1/4 tank left and then refill. I figure most should be run thru by second tank.
  11. 04-27-2012 03:19 PM #11
    OK thanks. Howcome you do it right before an oil change? I just had my oil change done so I won't do that for a while. Will it do something to the oil and thats why you change it out?
  12. 04-27-2012 06:40 PM #12
    I've heard both. I do it just before oil change in hopes of getting debris out w oil change but I know many dealers do it when they service the car.
  13. Junior Member
    Mar 7th, 2012
    Denton, TX
    2008 Passat Lux wagon FSI auto; also Volvo 1800ES
    04-27-2012 09:26 PM #13
    I had used BG 44K in an Audi a few years ago. My very knowledgeable tech swore by it. I would also agree to use it before oil change, as it's sure to dissolve some crud somewhere in the engine.
    Where can I buy the Redline stuff?
