I don't know of any place that sells solid trans mounts. What makes you think you will need that?
#1
I'm going to replace mine and just wanted to see what people had to say about how much of a difference they observed.
Thanks
Want to trade? Check my FS posts !
#2
#3
not that solid. I mean the solid rubber ones as opposed to the hydraulic ones. I've heard that some thought the solid rubber ones created too much vibration. I tryed the rear engine mount with the poly insert and that was too much vibration for me.
#4
Then you may want to consider the hydraulic version.
Many of my previous car projects had polyurethane and solid bushings and mounts. Too much vibration for daily driving in my opinion. Passengers don't like it much either.
My last two project cars went back to OEM standard engine mounts and bushings. (A sign of my old age i guess)
85 Golf GL with 2.0l 16v
90 Corrado G60 TEC 2RS
corradog60project.blogspot.com
mkiigolfproject.blogspot.com
#6
i got the "solid" G60 mount from BFI, wouldn't say it's TOO much vibration
#7
Solid rubber, g60
OIF 06-07: Hospital Corpsman FMF. Al Habbaniyah, Al-Anbar Province, Iraq.
Mk2 16v parts for sale.
Mk2 Golf_GL 16v @ Streets of Willow Raceway.
Project Гольф Мк2 (Carbed)
#8
Solid are better hydro can catastrophically fail and snap of pretty bad
You can always shim the front motor mount with a plate of steel a few mms thick so it doesn't wiggle in the bracket Or get the go kraut front cross member bar as it will space the bracket out some to fit it snugger
#9
TT use to sell solid mount. Here in Canada Concept 1 still sell them
http://store.concept1.ca/store/produ...r-Mount-SOLID/
#10
I replaced all my hydro mounts with solid rubber. I had the poly engine mount insert for a little while and it was definitely WAY too harsh, but I love just the rubber ones now. I couldn't feel anything with the hydros before.
02.5 24v GTI: 2.9L, JE pistons, IE rods, eurospec 264/260° cams, Wavetrack LSD, TT dp/hiflow cat, 2.5" TT catback/ borla, Oettinger, 18x8 RS-GT on BF Goodrich, Brembo GT front BBK, 28mm/25mm Neuspeed swaybars, H&R coilovers, etc. More info & pics
90.5 16v GLI: Calypso green, >30mpg, 15x7.5 RMs, 195/50 Yoko Sdrives, PSS9s, 2.25" TT catback/ borla, USRT shift kit, .80 5th.
