Results 1 to 10 of 10
Thread: FS: 98 VW Passat 1.8t 5-speed 92k miles! Light hit in front $1400
    Mar 5th, 2003
    Buffalo, NY
    83 rabbit gti
    04-27-2012 02:28 PM #1
    1998 Volkswagen Passat Sedan
    5-speed Manual Transmission
    1.8L 20 valve Turbocharged 4 cylinder engine
    92,000 Miles
    Heated front seats
    Moonroof
    Power windows and locks
    Air Conditioning works, could be colder with a can of freon
    This Passat has been involved in a front end collision and comes with a Salvage rebuildable title. The main damage is to the front bumper, grille, hood, and RF fender. The driver and passenger airbags have been deployed, these can be found on ebay for less than $100 a set. The RF steel wheel has bends on the outer lip as pictured (spare wheel ok). The radio is missing. It starts easily, runs and drives well (no check engine light), I have driven it about 250 miles recently with no break-downs.
    On the certificate where the damage is checked for what was affected/needs to be repaired only "body" is marked, "air bags" is not.
    $1400
    Great car for a swap, too. No immobilizer
    Located in Buffalo, NY. Delivery is available within 400 miles for $.85 a mile.
    Mar 5th, 2003
    Buffalo, NY
    83 rabbit gti
    05-03-2012 02:10 PM #2
    ttt, still have it
    Mar 5th, 2003
    Buffalo, NY
    83 rabbit gti
    05-17-2012 04:14 PM #3
    btw for you New York Staters: the mv-50 (salvage title document) doesn't have anything but "body" checked under "damaged."
    Airbags are only $70 for the pair on ebay!
  4. Member
    Mar 5th, 2003
    Buffalo, NY
    83 rabbit gti
    06-26-2012 03:38 PM #4
    STILL HAVE IT $1300 TAKES IT. Runs & drives fine
  5. Member manfredwerner's Avatar
    Jan 29th, 2007
    staten island/brooklyn
    all gone, looking for another one
    06-28-2012 12:02 AM #5
    to pass through inspection in ny you will have to have brand new airbags purchased from a dealer with receipts... that's why they totalled it. GL with the sale though, coz not all states are nuts, you can register it with used bags in other states and then re-register it in ny...
  6. 06-29-2012 07:47 PM #6
    Let me take if off your hands for $500 cash this weekend
    Mar 5th, 2003
    Buffalo, NY
    83 rabbit gti
    07-02-2012 12:33 PM #7
    Quote Originally Posted by manfredwerner View Post
    This is true. However on the mv907a for this Passat (the NY salvage document) they didn't check off "air-bags" on the back of the document, there is nothing alluding to the airbags needing replacement.
    Quote Originally Posted by jimmycorp View Post
    I am negotiable slightly, however that is too low. Thank you for your offer
  8. 07-06-2012 12:42 AM #8
    Needs quite some work, no way to tell the real damage until you lift her up.
    Sent from my HTC Glacier using Tapatalk
    Mar 5th, 2003
    Buffalo, NY
    83 rabbit gti
    07-06-2012 01:05 AM #9
    Quote Originally Posted by Watergunz View Post
    I have a lift and a shop. the impact was in the grill as all evidence suggests. Unsure how you could even think that obvious, concentrated damage could have made it further.
  10. Member
    Mar 5th, 2003
    Buffalo, NY
    83 rabbit gti
    07-09-2012 04:32 PM #10
    Still for sale.
    don't forget, I have a truck and trailer and can deliver within 400 miles for $0.95 per mile.
    I can also drive it wherever as long as you can give me a ride back. I've taken it on a few hundred mile road trip without incident.
