Check your fuses and all terminals
Sent from my SGH-T989 using Tapatalk 2
#1
Hello,
I drove my 2006 Passat 2.0T at night a few days ago. And I forgot to shut off the light. It came out that my battery was drained completely. After doing a jump start under my friend's help, I was able to run it again. But my radio remains dead, meaning it won't turn on by all means. Has any one encountered similar problem? Any help?
Thanks in advance.
#2
#3
isnt there something to do with the radio code or something?
#4
#5
#6
There's also a fuse on the back of the radio. You might want to check that one.
2007 Candy White/Black Passat 2.0T Wolfsburg Edition| APR Stage 2+ | APR HPFP | Forge WINtake | S3 Intercooler | B&B 3" Turbo-Back Exhaust | Dogbone Insert | FK Silverline+ Coilovers | Front Lip Spoiler/Hi-Def Sideskirts | Votex Trunk Lip Spoiler | R-Line Fog Grilles | Clear Corners | HID Kit - low beams & fogs | RCD-510 | Podi Boost gauge | R-Line Pedals | GTI Steering Wheel |
#7
Are you sure the battery is fully charged again now? Sometimes low battery can do weird things on this car.
Owning a VW is like having a hot girlfriend that's mentally unstable
#8
Sometimes when you jump a car, fuses blow on items that were left on. I try to turn everything off when I turn the car off for reasons like this.
2006 Passat 2.0T Tiptronic | Unitronic Stage 1+ | Rokkor Coil Overs | White Line Control Arm Bushings | BFI Tranny Mount | Nuespeed P-Flo Intake | Newsouth Boost Gauge | AWE DV | BSH PCV fix | eBay Climate Knobs | Autotech Exhaust | DDM HIDs | Stereo Upgrades | Bentley Manual | VCDS
2008 Touareg VR6
