Results 1 to 8 of 8
Thread: Drained battery, dead radio
  1. 04-27-2012 04:41 PM #1
    Hello,
    I drove my 2006 Passat 2.0T at night a few days ago. And I forgot to shut off the light. It came out that my battery was drained completely. After doing a jump start under my friend's help, I was able to run it again. But my radio remains dead, meaning it won't turn on by all means. Has any one encountered similar problem? Any help?
    Thanks in advance.
  2. 04-27-2012 05:14 PM #2
    Check your fuses and all terminals
    Sent from my SGH-T989 using Tapatalk 2
  3. Member nodashi's Avatar
    Mar 20th, 2012
    Whidbey Island, WA
    2006 FSI 2.0t Passat
    04-27-2012 05:16 PM #3
    isnt there something to do with the radio code or something?
  4. 04-27-2012 08:21 PM #4
    Quote Originally Posted by SLNDTDEATH View Post
    The fuse should be alright cause I replaced it. I don't understand because everything was working before I drained my battery.
  5. 04-27-2012 08:21 PM #5
    Quote Originally Posted by nodashi View Post
    Yeah, I know my code. But the radio doesn't turn on at all.
  6. Member low_passat's Avatar
    Sep 11th, 2010
    Goodyear, AZ
    04-27-2012 09:53 PM #6
    There's also a fuse on the back of the radio. You might want to check that one.
    2007 Candy White/Black Passat 2.0T Wolfsburg Edition| APR Stage 2+ | APR HPFP | Forge WINtake | S3 Intercooler | B&B 3" Turbo-Back Exhaust | Dogbone Insert | FK Silverline+ Coilovers | Front Lip Spoiler/Hi-Def Sideskirts | Votex Trunk Lip Spoiler | R-Line Fog Grilles | Clear Corners | HID Kit - low beams & fogs | RCD-510 | Podi Boost gauge | R-Line Pedals | GTI Steering Wheel |
  7. Member najel's Avatar
    Apr 10th, 2008
    Mankato MN & Bielefeld Germany
    03 Jetta GL & 06 Passat 2.0t
    04-28-2012 09:05 AM #7
    Are you sure the battery is fully charged again now? Sometimes low battery can do weird things on this car.
    Owning a VW is like having a hot girlfriend that's mentally unstable
  8. Member Tutti57's Avatar
    Jun 20th, 2011
    Rochester, NY
    2006 Passat 2.0T and 2008 Touareg VR6
    04-28-2012 09:21 AM #8
    Sometimes when you jump a car, fuses blow on items that were left on. I try to turn everything off when I turn the car off for reasons like this.
    2006 Passat 2.0T Tiptronic | Unitronic Stage 1+ | Rokkor Coil Overs | White Line Control Arm Bushings | BFI Tranny Mount | Nuespeed P-Flo Intake | Newsouth Boost Gauge | Rev D Diverter Valve | BSH PCV fix | eBay Climate Knobs | Autotech Exhaust | DDM HIDs | Stereo Upgrades | Bentley Manual | VCDS
    2008 Touareg VR6
