VWVortex.com - Need help!!!! Transmission
    Results 1 to 4 of 4
    Thread: Need help!!!! Transmission
    1. Member BigD_GTI's Avatar
      Apr 19th, 2012
      MD
      02 GTI and 05 Audi A4 USP 1.8QT
      04-27-2012 08:13 PM #1
      i just got a 05 Audi A4 S Line Quattro and i need to know if anyone can help me with this to figure out whats wrong with it, its an auto trans and i put it in D and R but it takes high rpms to make it move if it moves at all, sometimes it does and sometimes it doesnt at all. I put it on the VCDS and its not throwing any tranny codes so idk if somethings wrong with the trans. Any help would be greatly appreciated. Thanks
    2. Member gregg3gs's Avatar
      May 15th, 2004
      Atlanta, GA (the A)
      04_A4_1.8TQ_SMS_K04+, 08_X5_4.8i; Previous: 01_A4_1.8_TQ, 01_Golf, 01_Jetta, 93_Passat_VR6_+_Garrett
      04-27-2012 09:18 PM #2
      got fluid?
    3. Member BigD_GTI's Avatar
      Apr 19th, 2012
      MD
      04-27-2012 09:28 PM #3
      how would i find out if it does or not?
    4. Member gregg3gs's Avatar
      May 15th, 2004
      Atlanta, GA (the A)
      04-29-2012 02:49 PM #4
      look under the car (preferably on stands or lift) and look at the transmission body driver side (I think).
      You should notice two big allen bolts one over the other, they are big 14 or 17mm.
      If you are parked on level surface you can remove the top bolt and stick your finger in the opening
      You should have fluid dripping out or right at your finger, if you do not, you are low.
      I am not sure how much fluid does automatic trany hold but my stick did have almost 3L and half was missing by 130k.
      Good Luck.
