Results 1 to 7 of 7
Thread: In need of some help.....
  1. Member DOQ fastlane's Avatar
    Feb 25th, 2009
    DubsofQueens.com
    Stage 2 CC
    04-27-2012 08:24 PM #1
    Over the past few days I've noticed when I come to a stop the rpms drop unusually low and almost stalled a few times.
    I just installed the awe Turbo outlet pipe and now when I come to a stop it stalls out when it hits 1k rpm.. Every time
    I took everything apart.. Checked it all and it seems tight, and don't hear or feel any leaks
    I called my mechanic (at home.. Great guy) and he mentions possible vacuum leak.
    He also says to try to disconnect the maf sensor and drive it again to see what happens..
    Crazy enough, it stops stalling.
    My mechanic said first thought may be the maf is going bad.. But nothing solid.
    I just wanted to hear your thoughts on this before I move forward on having it diagnosed..
    Dec 1st, 2009
    2010 CC 2.0T 6spd, 2012 CC Lux+ DSG, 2001 Corvette 6spd Z51
    05-01-2012 03:21 PM #2
    Do you have an aftermarket air filter? (the type that can be washed and re-oiled)?
  3. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    05-01-2012 04:36 PM #3
    Does your car build boost at all?
    If it doesn't check your TB
    You might want to check your MAP sensor as well, its on the TB pipe.
  4. Banner Advertiser SALES@RSWORX's Avatar
    Jun 28th, 2009
    Central NJ
    01.5 Audi Avant S4, AP2 S2000, TJ on 35s
    05-07-2012 01:11 PM #4
    Check that you didn't roll the seal where the outlet pipe connects to the intercooler.
    Redline Speed Worx
    APR|ADV.1|AQUAMIST|BBS|SOUTH BEND CLUTCH|FERREA|HRE|KW|UNITED MOTORSPORT|MAHLE|MILLTEK|PELOQUIN|SSP|STOPTECH
    www.RedlineSpeedWorx.com
  5. Member DOQ fastlane's Avatar
    Feb 25th, 2009
    DubsofQueens.com
    Stage 2 CC
    05-07-2012 01:13 PM #5
    Sorry I didn't update this... But Pat.. That is exactly what it was.
    Reinstalled and it's running like a raped ape.
    Boosting spikes at 22psi..holds at 19psi
  6. Banner Advertiser SALES@RSWORX's Avatar
    Jun 28th, 2009
    Central NJ
    05-07-2012 02:07 PM #6
    Glad I could "kind of" help My over the internet diagnostic skills were on point this morning
    Redline Speed Worx
  7. Member DOQ fastlane's Avatar
    Feb 25th, 2009
    DubsofQueens.com
    Stage 2 CC
    05-07-2012 02:59 PM #7
    All good at Dyno Day yesterday
