Page 1 of 2 1 2 LastLast
Results 1 to 35 of 37
Thread: Show me your ways
  1. Member Fuk It MkV's Avatar
    Jul 1st, 2011
    GeeTeeEyee on Pegadicks
    04-27-2012 08:52 PM #1
    Hey guys,
    Im looking to go air on my mkv gti. I was looking at Bag Riders Switchspeed kit.
    Now I've never done this and I'm a total noob about air. Ive done some research, but not too much good stuff (cause I don't know what I'm looking for ).
    Any information/tips/tricks/whatever about anything mkv air is greatly appreciated.
    Thanks
    | Instagrams: fukitmkv | I didn't build anything; I just bolted stuff on.
  2. Member Slo.Mo.Shun's Avatar
    Jan 13th, 2010
    S Florida
    Bagged MKVI JSW TDI
    04-27-2012 09:23 PM #2
    There is tons of good stuff here, you just got to get familiarized with the search terms.
    Here are some things you should know:
    - Get in contact with one of the forum's Air vendors, they will point you in the right direction.
    - You need a passenger side notch.
    - Buy nice or buy twice.
    - Use locktite 545 or pink teflon tape.
    - Get only DOT fittings.
    - 3/8ths line is fast, 1/4 line is nice and slow (1/4 line is easier to route).
    -All metal water traps are best.
    -444s are awesome compressors AZs rock too.
    -I recommend slam speciality bags for the rear, preferably on tubular control arms.
    - Non XL rears apear to work better than the LX ones.
    -Route your lines away from harms way (Exhaust)
    - Reliability comes from a quality instal (Mostly).
  3. Member Fuk It MkV's Avatar
    Jul 1st, 2011
    04-27-2012 09:35 PM #3
    Thank you I fixed my first post haha.
    What do you think about this though:
    I just want to know I get a proper kit the first time.
  4. Member
    Jan 4th, 2012
    So cal
    03 jetta
    04-27-2012 09:40 PM #4
    That looks like a pretty good kit I came from a bagged Nissan and I've bagged my 02 hd f150 so I ran 1/2 lines n valves with AZ compressors but baggin VWs is all new territory haha
    Proof
    iPhone pics haha
  5. Member Slo.Mo.Shun's Avatar
    Jan 13th, 2010
    S Florida
    Bagged MKVI JSW TDI
    04-27-2012 09:43 PM #5
    I would just change the rear bags to the non XL versions. They are easier to install, dont rub, and still go really low.
    What rear shocks are you using ?
  6. Member Fuk It MkV's Avatar
    Jul 1st, 2011
    04-27-2012 09:49 PM #6
    Quote Originally Posted by Slo.Mo.Shun View Post
    Should I get the performance series instead? Id rather not spend anymore money haha.
    And Im just going to use the stock ones for now.
  7. Member Slo.Mo.Shun's Avatar
    Jan 13th, 2010
    S Florida
    Bagged MKVI JSW TDI
    04-27-2012 09:55 PM #7
    Trust me, get the performance ones. Its the same bag as the XL, but it mounts easier and is less prone to failure.
    Your stock shocks wont last and will ride poorly.
  8. Member Fuk It MkV's Avatar
    Jul 1st, 2011
    04-27-2012 10:02 PM #8
    Sounds good.
    And I was going to replace the shocks, just wait till their done. I have some kws I might throw on or buy something else.
  9. Member Slo.Mo.Shun's Avatar
    Jan 13th, 2010
    S Florida
    Bagged MKVI JSW TDI
    04-29-2012 08:52 AM #9
  10. Member Rat4Life's Avatar
    Oct 13th, 2004
    Fair Lawn, NJ
    lada 2101,rx7,bmw 318i,87 golf gt,93 1.8t two tone,01 flat blue mk4,02 gti 1.8t. 1JZ e21 in works
    04-29-2012 09:35 AM #10
    this rear kit is designed for solid beam rear only,not one found on any mk5's
    Quote Originally Posted by Andrew@ORT View Post
    No sir, it will not. It will only work for a solid rear beam Mk6.
    Complete air ride installs,frame notching,welding, in north jersey.
    http://www.flickr.com/photos/rat4life/
    roll cages,race rally preps in upstate new york http://www.rktmotors.com/Gallery.html
    follow me on instagram RAT4LIFE
  11. Member Slo.Mo.Shun's Avatar
    Jan 13th, 2010
    S Florida
    Bagged MKVI JSW TDI
    04-29-2012 08:46 PM #11
    True, I jumped the gun.
    I thought it was something like the bagyards.
  12. Member Fuk It MkV's Avatar
    Jul 1st, 2011
    04-29-2012 09:04 PM #12
    Update -
    Im going to just buy a used kit from a guy I know on here. This is what it'll be:
    -Airlift Slam XL fronts
    -Universal Airhouse II rears with D-cups
    -Easystreet management
    -Viair 400c compressor
    -5 gallon skinny tank
    -All airlines precut
    -Power wire
    -Everything else you need
    Comes with full trunk setup with false floor.
  13. Member Slo.Mo.Shun's Avatar
    Jan 13th, 2010
    S Florida
    Bagged MKVI JSW TDI
    04-29-2012 09:13 PM #13
    Pre cut air line ?
  14. Member Fuk It MkV's Avatar
    Jul 1st, 2011
    04-29-2012 09:15 PM #14
    Pre cut air line ?
    we have the same size car so I'm just going to re use the air lines he was using
  15. Member
    Oct 16th, 2009
    SF Bay Area
    2008 MkV GTI
    04-29-2012 09:44 PM #15
    - Use locktite 565 or pink teflon tape.
    does the driver side not need a notch?
  16. Member Slo.Mo.Shun's Avatar
    Jan 13th, 2010
    S Florida
    Bagged MKVI JSW TDI
    04-29-2012 09:53 PM #16
    No
  17. Member Twilliams83's Avatar
    Jan 24th, 2011
    Wildomar, CA
    04-29-2012 10:11 PM #17
    when you say easy street management are you referring to autopilot v1? because lots of users have problems with that system.
    Hella4¯\_(ツ)_/¯ My Flickr
  18. Member Fuk It MkV's Avatar
    Jul 1st, 2011
    04-29-2012 10:14 PM #18
    Quote Originally Posted by Twilliams83 View Post
    This one
  19. Member Twilliams83's Avatar
    Jan 24th, 2011
    Wildomar, CA
    04-29-2012 10:50 PM #19
    Quote Originally Posted by Fuk It MkV View Post
    This one
    yeah i would personally stay away from that system.
  20. Member Fuk It MkV's Avatar
    Jul 1st, 2011
    04-29-2012 11:18 PM #20
    What types of problems have you heard?
    Sent from my iPhone using this app that I paid 2.99 for
  21. Member Twilliams83's Avatar
    Jan 24th, 2011
    Wildomar, CA
    04-29-2012 11:39 PM #21
    if you do a quick search you will find all kinds of issues man. The accuracy is horrible.
  22. Member Fuk It MkV's Avatar
    Jul 1st, 2011
    04-29-2012 11:41 PM #22
    I did one and found some with faulty relays and ecus, that's why I wanted to know what you heard. I've heard from people that it's fairly accurate though. Obviously not as close as the v2, but still
  23. Member gtipwnz's Avatar
    Jun 6th, 2010
    Wisconsin
    Mk3 Jetta Wolfsburg, Mk6 GTI (sold)
    04-30-2012 08:35 PM #23
    My vote will always be with E-level, but that's the only one I have any experience with. Whoever said Airlift performance rears, right on. They mount easier and don't have any issues so far, except where the metal crimps the bag on the bottom one of mine chewed through. It was replaced for free though.
  24. Member Rat4Life's Avatar
    Oct 13th, 2004
    Fair Lawn, NJ
    04-30-2012 08:43 PM #24
    Update -
    -Power wire
    do not suggest reusing airline, always want to do a fresh cut and run new line even with a used kit.
    also if the price difference is less than $500 i would always recommend new parts over any, even barely used, you just never know how it was installed and how it was used.
  25. Member Lawn_Mower's Avatar
    Jul 15th, 2008
    Mooresville, NC
    06 GTI
    04-30-2012 08:55 PM #25
    also air line is CHEAP, just get new line.
    Lower-IT
    // DROP // DRAG // DESTROY
    OpenRoadTuning
  26. Member Fuk It MkV's Avatar
    Jul 1st, 2011
    04-30-2012 09:40 PM #26
    Actually guys I bought a new kit today from bagriders and it'll be here wednesday
  27. Member Twilliams83's Avatar
    Jan 24th, 2011
    Wildomar, CA
    04-30-2012 09:57 PM #27
    what did you end up going with
  28. Member Fuk It MkV's Avatar
    Jul 1st, 2011
    04-30-2012 10:14 PM #28
  29. Member Rat4Life's Avatar
    Oct 13th, 2004
    Fair Lawn, NJ
    04-30-2012 10:18 PM #29
    good choice man
  30. Member Twilliams83's Avatar
    Jan 24th, 2011
    Wildomar, CA
    04-30-2012 10:29 PM #30
    you will be much happier with accuair man
  31. Member Slo.Mo.Shun's Avatar
    Jan 13th, 2010
    S Florida
    Bagged MKVI JSW TDI
    05-01-2012 05:05 AM #31
    Ride-tech or a V2.
    Cut those lines at the same length in pairs. Fronts and rears.
  32. Member Lawn_Mower's Avatar
    Jul 15th, 2008
    Mooresville, NC
    06 GTI
    05-01-2012 09:36 AM #32
    You should be happy with that kit.
    Lower-IT
    OpenRoadTuning
  33. 05-01-2012 10:26 AM #33
    You will need rear shock if you dont have any
  34. Banner Advertiser Andrew@ORT's Avatar
    Nov 23rd, 2008
    Malvern, PA
    coal powered torque monster.
    05-01-2012 10:33 AM #34
    8AWG is a little small for wiring. If you decide to jump up to two compressors, you should run 6AWG. Otherwise, you'll be happy with the SwitchSpeed
  35. Member Lawn_Mower's Avatar
    Jul 15th, 2008
    Mooresville, NC
    06 GTI
    05-01-2012 10:46 AM #35
    Quote Originally Posted by MatGervais View Post
    lol i saw this and posted it originally. but then i went back and looked, saw he has koni's. Ninja edit ftw.
    Lower-IT
    OpenRoadTuning
