I am of no help.. other than to say, why?I can't see anyone needing on oil cooler in this car..
#1
I have all the parts to put a FMOC on my CC left over from when I sold my Passat, all I would need is 2 fittings. If I decide to jump the gun and go for it I would have to switch to a regular oil filter. Is there anything i should expect other than it getting messy when I take off the filter for an oil change? Is there anything special about our oil filters other than having a male thread on the end instead of a female?
#2
#3
Because the oil runs through the turbo and I want to keep the oil cooler to keep the turbo happy.
#4
I just finished the install, no leaks or other problems but I am still curious........
#5
#6
I don't go to the track but for now it is my daily driver and I often get stuck in stop and go driving.
I took picts for a write up but it doesn't seem like there is any interest in this.
#7
Can you post pictures of the install? It would help and maybe this could be added the FAQ.
#8
There is some interest, posting the pictures would be good. How did you connect the cooler ? did you use a custom sandwich plate? Does it have an oil thermostat, to bypass the oil cooler flow when the oil is cold?
#9
I will get started on a write up, below are some picts, as well as a few answers to your questions.
To connect it you can see what I had tig wlded together. I used the fitting from a stock CC filter cut at the base. I drilled it out slightly so the pipe for the oil filter for a B5.5 passat could fit inside. I would have taken pictures before i put it in but once it was in i couldn't get it out without damaging the threads. I can have an exact piece made for you for like $25-30 bucks.
I used a MOCAL sandwich plate that has a thermostat that i had laying around. You can get one for $100 and most likely piece the kit together for like $200 or so depending on the core, lines fittings etc.
Lastly, I had to shave the plate and the fitting to clear the 2 coolant pipes that run by the oil filter.
AND IT DOES CLEAR THE SUPPORT, BARELY
