Results 1 to 9 of 9
Thread: Is there anything special about our oil filters? Thinking of putting on a front mount oil cooler....
  1. 04-27-2012 09:28 PM #1
    I have all the parts to put a FMOC on my CC left over from when I sold my Passat, all I would need is 2 fittings. If I decide to jump the gun and go for it I would have to switch to a regular oil filter. Is there anything i should expect other than it getting messy when I take off the filter for an oil change? Is there anything special about our oil filters other than having a male thread on the end instead of a female?
    May 30th, 2008
    NJ
    04-27-2012 11:21 PM #2
    I am of no help.. other than to say, why? I can't see anyone needing on oil cooler in this car..
  3. 04-28-2012 01:18 AM #3
    Because the oil runs through the turbo and I want to keep the oil cooler to keep the turbo happy.
  4. 04-28-2012 05:21 PM #4
    I just finished the install, no leaks or other problems but I am still curious........
    May 30th, 2008
    NJ
    04-28-2012 08:51 PM #5
    Quote Originally Posted by NUISANCECC View Post
    yea, I got that.. Just saying, 99.9% of CC owners will never push their car to the point of needing an oil cooler, go on the track often?
    And seems like no one knows to much about it on the cc, but if it's in, and not leaking.. Then nothing to worry about in my book.
  6. 05-03-2012 02:38 AM #6
    I don't go to the track but for now it is my daily driver and I often get stuck in stop and go driving.
    I took picts for a write up but it doesn't seem like there is any interest in this.
  7. Member VdubXXIV's Avatar
    Feb 13th, 2008
    2003 VW Jetta, 2012 CC R-line
    05-03-2012 08:42 AM #7
    Can you post pictures of the install? It would help and maybe this could be added the FAQ.
    Dec 1st, 2009
    2010 CC 2.0T 6spd, 2012 CC Lux+ DSG, 2001 Corvette 6spd Z51
    05-03-2012 09:32 AM #8
    There is some interest, posting the pictures would be good. How did you connect the cooler ? did you use a custom sandwich plate? Does it have an oil thermostat, to bypass the oil cooler flow when the oil is cold?
  9. 05-06-2012 03:53 AM #9
    Quote Originally Posted by CC'ed View Post
    I will get started on a write up, below are some picts, as well as a few answers to your questions.
    To connect it you can see what I had tig wlded together. I used the fitting from a stock CC filter cut at the base. I drilled it out slightly so the pipe for the oil filter for a B5.5 passat could fit inside. I would have taken pictures before i put it in but once it was in i couldn't get it out without damaging the threads. I can have an exact piece made for you for like $25-30 bucks.
    I used a MOCAL sandwich plate that has a thermostat that i had laying around. You can get one for $100 and most likely piece the kit together for like $200 or so depending on the core, lines fittings etc.
    Lastly, I had to shave the plate and the fitting to clear the 2 coolant pipes that run by the oil filter.
    AND IT DOES CLEAR THE SUPPORT, BARELY
